    We are upgrading our website
Document ID: c03896503
Version: 1
NOTEBOOK - System BIOS Update F.42 for 2170p
Release date : 13-Aug-2013
Last updated : 13-Aug-2013
รายละเอียดการเปลี่ยนแปลง
  • Updated the Intel PXE code to version 1.0C.
  • Fixed an intermittent issue where the computer is unable to power on by pressing the power button.
  • Fixed an intermittent issue where the F10 (BIOS) Setup Power On feature may not automatically wake up the computer from the off state.
REASON FOR CHANGE
Quarterly refresh for the factory and Web release.
IMPACT OF CHANGE
After upgrading to this BIOS version, you will not be able to downgrade to versions older than F.30, if the Secure Boot option has been enabled in F10 (BIOS) Setup.
If upgrading to this BIOS from a version older than F.30, it is recommended that the user enter the F10 (BIOS) Setup and restore defaults after backing up existing F10 (BIOS) Setup settings. For information on restoring F10 (BIOS) Setup settings, see http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c03029668&prodTypeId=321957&prodSeriesId=5257511.
Components affected:
HP EliteBook 2170p Notebook PC
DATE OF CHANGE
Effective date : 16-Jul-2013
Hardware platforms affected : HP EliteBook 2170p Notebook PC
