HP Z Display Z24i 24-inch IPS LED Backlit Monitor - Identifying Components
Front view
Figure : Front view
Item
Button
1
Menu
Opens, selects or exits the OSD menu.
2
Minus "-"
If the OSD menu is On, press to navigate backward through the OSD menu and decrease adjustment levels.
3
Plus "+"/Input
  • If the OSD menu is On, press to navigate forward through the OSD menu and increase adjustment levels.
  • If the OSD menu is inactive, press to activate the input button that chooses the video signal input (VGA, DVI, or DisplayPort).
4
OK/Auto Adjust
  • If the OSD menu is On, press to select the highlighted menu item.
  • If the OSD menu is inactive, press to activate the auto adjustment feature to optimize the screen image.
5
Power1
Turns the monitor On or Off.
LED:
  • fully powered = white
  • sleep mode = amber
  • sleep timer mode = flashing amber
1: Be sure the master power switch on the rear of the monitor is in the On position to turn On the monitor.
