HP Officejet 2620 All-in-One and HP Deskjet Ink Advantage 2645 All-in-One Series - Copy Text or Mixed Documents
To make a black or color copy
  1. Load paper in the input tray.
    Figure : Insert a stack of paper
  2. Do one of the following to load the original:
    • Load the original print-side down on the right front corner of the scanner glass.
      Figure : Load the original
    • Load the original print-side up, head first, in the Automatic Document Feeder (ADF).
      Figure : Load the original in ADF
  3. Select Copy from the Home screen on the printer display, and then press OK to access the Copy menu.
    If you do not see Copy on the printer display, press the Home button, and then press the Up and Down buttons until you see Copy.
  4. From the Copy menu, select Copies, press the Up and Down buttons to increase or decrease the number of copies, and then press OK to confirm.
  5. Select Start Black Copy or Start Color Copy, and then press OK to make a black or color copy.
More copy features
More copy features
The Copy menu on the printer display allows you to easily start a black or color copy and select number of copies. You can also easily change the copy settings, such as changing the paper type and size, adjusting the darkness of the copy, and resizing the copy.
While in the Copy menu, press the Up and Down buttons to select among settings.
  • Paper Type: Selects paper size and paper type. A plain paper setting will print in plain paper normal print quality. A photo paper setting will print in photo paper best quality.
  • Resize: Controls the size of the image or document to be copied.
    • Actual Size: Makes a copy that is the same as the size of the original, but the margins of the copied image may be clipped.
    • Fit to Page: Makes a copy that is centered with a white border around the edges. The resized image is either enlarged or reduced to fit the size of the selected output paper.
      The scanner glass must be clean to make sure the Fit to Page feature works properly.
    • Custom Size: Allows you to increase the size of the image by selecting values greater than 100% or reduce the image size by selecting values less than 100%.
  • ID Card Copy: Allows you to copy both sides of an ID card.
  • Lighter / Darker: Adjusts the copy settings to make copies lighter or darker.
Country: Flag Thailand
