Document ID: c03892146
Version: 1
HP rp5800 Point of Sale System - Black Magic Intensity Pro Card Does Not Function Properly When Installed in PCIe X1 Slot
Release date : 08-Aug-2013
Last updated : 08-Aug-2013
DESCRIPTION
Customers may experience one or more of the following symptoms when a Black Magic Intensity Pro video card is installed in an rp5800 PCI-Express (x1) slot or Riser Card:
  • System hang during Windows restart/shutdown.
  • System hang when installing or uninstalling the Black Magic Intensity Pro drivers.
  • A message prompting the user to update the Black Magic Intensity Pro firmware.
  • Flickering in video being captured while using Black Magic Media Express software.
sourceInformation
SCOPE
Systems:
  • HP rp5800 Point of Sale System
Operating Systems:
  • Microsoft Windows 7 Enterprise (32-bit)
RESOLUTION
To resolve these issues, perform the following steps:
BIOS
  • Press F10 on startup to enter BIOS.
  • Navigate to the " Power" menu and select " OS Power Management".
  • Disable " Runtime Power Management".
  • Change " Idle Power Savings" from " Extended" to " Normal".
  • Exit BIOS.
Windows 7 Operating Systems
  • Navigate to " Power Options" in " Control Panel".
  • Click " Change Plan Settings" under the " Current System Power Plan".
  • Click " Change Advanced Power Settings".
  • Click " Change settings that are currently unavailable" to change any advanced settings.
  • Expand " PCI Express", expand " Link State Power Management" and select " Off"
  • Click " Apply" and click " OK".
  • Close " Control Panel".
Hardware platforms affected : HP rp5800 Retail System
Operating systems affected : Microsoft Windows 7 Enterprise (32-bit) (deleted)
Support Communication Cross Reference ID : IA03892146
