HP Z Display Z23i 23-inch IPS LED Backlit Monitor - Overview
Product description
Product features
Feature
Model
Z23i
Type
IPS LED
58.42 cm wide screen (23 inches wide screen)
Viewable Image size
58.42 cm diagonal (23–inch diagonal)
Maximum Weight (Unpacked)
6.2 kg (13.64 lbs)
Tilt range
-5° to + 30° vertical
Pivot Rotation
Yes
Video signal input
VGA, DVI, or displayport
On-Screen Display (OSD) adjustments
  • Brightness
  • Contrast
  • Color
  • Image control
  • OSD control
  • Management
  • Language
  • Factory reset
  • Input control
Swivel and height adjustment capabilities
360°
Security Lock-Ready
Yes
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
