    Fix HP Printer issue on macOS
HP LaserJet Pro MFP - Requirements when configuring Outgoing E-mail Profiles, E-mail Options, and E-mail Address Book fields
This document lists the different fields used to configure Scan to E-mail for an HP LaserJet Pro MFP, including Outgoing E-mail Profiles, E-mail Options, and E-mail Address Book fields, and the maximum length and valid input values required for each.
For instructions on how to set up an outgoing email profile, go to Configure Scan to E-mail (c03231533) (in English).
The Scan to E-mail feature must have at least one outgoing e-mail profile set up before it can be used. The outgoing e-mail profiles can be setup, edited or deleted via the products Embedded Web Server, or via the Scan to E-mail Wizard software. There can be up to 20 outgoing profiles saved. Following are the valid input values and lengths that are supported for creating an outgoing e-mail profile:
Field
Length
Valid Value
Outgoing e-mail address
50 maximum
All ASCII values
Display name
25 maximum (Unicode)
Any UTF-8 values
SMTP server
100 maximum
All ASCII values
SMTP port
Integer value from 0-65535
SMTP User ID
50 maximum
All ASCII values
SMTP password
50 maximum
All ASCII values
PIN
4 exactly
Integer – Must be 4 digits
PIN confirm
4 exactly
Must match PIN
Valid formats for the SMTP User ID can be entered as follows but it is up to the SMTP server to parse out the domain.
  • Normal username
  • username@domain.com
  • domain.com\username (must be backslash\)
E-mail options
The Embedded Web Server also allows the setup of default e-mail options. The following are valid input values and lengths that are supported for these default options.
Field
Length
Valid Value
E-mail subject
80 maximum
Unicode [a-z] [0-9]
Body text
512 maximum
Unicode [a-z] [0-9]
File name prefix
20 maximum
Unicode [a-z] [0-9]
E-mail Address Book
The device will have the ability to save up to 50 individual or up to 49 group e-mail entries. Groups cannot be added to groups to prevent circular references. The E-mail Address Book can be edited via the control panel or the Embedded Web Server. Up to 51 destinations (the size of the e-mail address book plus 1) can be selected to send to.
Field
Length
Valid Value
Contact e-mail address
50 maximum
All ASCII values
Contact name
Any UTF-8 values
