Document ID: c03841955
Version: 1
HP Notebook PCs - Drive Encryption Pre-Boot Authentication Appears After F11 Recovery
Release date : 15-Jul-2013
Last updated : 15-Jul-2013
DESCRIPTION
The HP ProtectTools 8.0 Drive Encryption pre-boot authentication screen continues to appear after an F11 recovery, although Drive Encryption appears as disabled in the HP ProtectTools Security Manager.
SCOPE
Computers:
  • HP EliteBook 2170p Notebook PC
  • HP EliteBook 2560p Notebook PC
  • HP EliteBook 2570p Notebook PC
  • HP EliteBook 2760p Tablet PC
  • HP EliteBook 8460p Notebook PC
  • HP EliteBook 8460w Mobile Workstation
  • HP EliteBook 8470p Notebook PC
  • HP EliteBook 8560p Notebook PC
  • HP EliteBook 8570p Notebook PC
  • HP EliteBook 8570w Mobile Workstation
  • HP EliteBook 8760w Mobile Workstation
  • HP EliteBook 8770w Mobile Workstation
  • HP EliteBook Folio 9470m Notebook PC
  • HP Folio 13-2000 Notebook PC
  • HP ProBook 4230s Notebook PC
  • HP ProBook 4330s Notebook PC
  • HP ProBook 4331s Notebook PC
  • HP ProBook 4340s Notebook PC
  • HP ProBook 4341s Notebook PC
  • HP ProBook 4430s Notebook PC
  • HP ProBook 4431s Notebook PC
  • HP ProBook 4435s Notebook PC
  • HP ProBook 4436s Notebook PC
  • HP ProBook 4440s Notebook PC
  • HP ProBook 4441s Notebook PC
  • HP ProBook 4445s Notebook PC
  • HP ProBook 4530s Notebook PC
  • HP ProBook 4535s Notebook PC
  • HP ProBook 4540s Notebook PC
  • HP ProBook 4545s Notebook PC
  • HP ProBook 4730s Notebook PC
  • HP ProBook 5330m Notebook PC
  • HP ProBook 6360b Notebook PC
  • HP ProBook 6460b Notebook PC
  • HP ProBook 6470b Notebook PC
  • HP ProBook 6560b Notebook PC
  • HP ProBook 6565b Notebook PC
  • HP ProBook 6570b Notebook PC
  • HP Slate 500 Tablet PC
RESOLUTION
The authentication screen will accept the original password and encryption key to access the computer.
If Pre-Boot Security was enabled when Drive Encryption was activated, complete the following procedure to disable the pre-boot authentication:
  1. Re-install HP ProtectTools 8.0.
  2. Open the HP ProtectTools Administrative Console.
  3. In the left pane, expand Security. Select Features.
  4. In the right pane, uncheck Pre-Boot Security. Click Next.
  5. Click Finish.
If Pre-Boot Security was not enabled when Drive Encryption was activated, complete the following procedure to disable the pre-boot authentication:
  1. Re-install Drive Encryption for HP ProtectTools 8.0.
  2. Open the HP ProtectTools Administration Console.
  4. In the right pane, check Drive Encryption. Click Next. Follow the prompts to activate Drive Encryption.
  5. Restart the computer.
  6. Open the HP ProtectTools Administration Console.
  7. In the left pane, expand Security. Select Features.
  8. In the right pane, uncheck DriveEncryption. Click Next. Follow the prompts to deactivate Drive Encryption.
Hardware platforms affected : HP EliteBook 2170p Notebook PC, HP EliteBook 2560p Notebook PC, HP EliteBook 2570p Notebook PC, HP EliteBook 2760p Tablet PC, HP EliteBook 8460p Notebook PC, HP EliteBook 8460w Mobile Workstation, HP EliteBook 8470p Notebook PC, HP EliteBook 8560p Notebook PC, HP EliteBook 8570p Notebook PC, HP EliteBook 8570w Mobile Workstation, HP EliteBook 8760w Mobile Workstation, HP EliteBook 8770w Mobile Workstation, HP EliteBook Folio 9470m Notebook PC, HP Folio 13-2000 Notebook PC, HP ProBook 4230s Notebook PC, HP ProBook 4330s Notebook PC, HP ProBook 4331s Notebook PC, HP ProBook 4340s Notebook PC, HP ProBook 4341s Notebook PC, HP ProBook 4430s Notebook PC, HP ProBook 4431s Notebook PC, HP ProBook 4435s Notebook PC, HP ProBook 4436s Notebook PC, HP ProBook 4440s Notebook PC, HP ProBook 4445s Notebook PC, HP ProBook 4530s Notebook PC, HP ProBook 4535s Notebook PC, HP ProBook 4540s Notebook PC, HP ProBook 4545s Notebook PC, HP ProBook 4730s Notebook PC, HP ProBook 5330m Notebook PC, HP ProBook 6360b Notebook PC, HP ProBook 6460b Notebook PC, HP ProBook 6470b Notebook PC, HP ProBook 6560b Notebook PC, HP ProBook 6565b Notebook PC, HP ProBook 6570b Notebook PC, HP Slate 500 Tablet PC
Support Communication Cross Reference ID : IA03841955
