    Windows 11 Upgrade Guide
HP EliteDesk 800 G1 Tower PC Product Specifications
Product features
Feature
Intel Q87 Express
Processors
Intel 4th Generation Core i5, i7 Processors
Memory
1600-MHz DDR3 SDRAM; (4) DIMM slots enabling up to 32GB, dual channel memory support
Webcam and microphone
Internal storage
Up to 500GB SATA hard drive; up to 500GB self-encrypting solid state drive; up to 160GB solid state drive
Removable storage
  • Slim DVD-ROM drive
  • Slim SuperMulti DVD drive
  • Slim BDXL Blu-ray Writer drive
  • (2) PCI Express x1 (v2.0)
  • (1) PCI Express x 16 (v2.0 - wired as x4)
  • (1) PCI Express x16 (v3.0)
  • (1) Optional PCI (v2.3)
Graphics
  • Integrated Intel HD Graphics
  • Discrete AMD Radeon HD 8350, 849030, NVIDIA NVS 310, 315, or NVIDIA GeForce GT630 graphics optional
Audio
  • DTS Studio Sound
  • Realtek ALC 221 Audio (all ports stereo)
  • Microphone and headphone jacks
  • Stereo audio line out and integrated speaker
Communications
Integrated Intel I217LM Gigabit Network Connection; optional wireless LAN card available
Ports and connectors
Front:
  • (2) USB 2.0 ports
  • (2) USB 3.0 ports, microphone, headphone
Rear:
  • (4) USB 2.0 ports
  • (2) USB 3.0 ports, stereo audio out, line in, RJ-45 Ethernet, PS/2 mouse and keyboard, VGA, (2) DisplayPort with multi-stream4, power connector, RS-232 serial port
Input devices
  • PS/2 keyboard
  • USB keyboard
  • Wireless Keyboard and Mouse
  • USB CCID SmartCard keyboard
  • USB PS/2 Washable keyboard
  • PS/2 mouse
  • USB Optical mouse
  • USB 1000dpi Laser mouse
  • USB PS/2 Washable Scroll mouse
Power
Internal 320-W power supply, Active PFC, up to 94% efficient
Physical specifications
Specification
Chassis (H x W x D)
399 x 170 x 442 mm (15.7 x 6.7 x 17.4 in)
System volume
30 L (1828 cu in)
System weight
9.3 kg (20.5 lb)
Packaging   (H x W x D)
295 x 500 x 590 mm (11.6 x 19.7 x 23.2 in)
Shipping weight
13.1 kg (28.8 lb)
Palletization profile
  • 4-units per layer
  • 8-layer max
  • 32-units per pallet
Audio specifications
Specification
Type
Integrated
HD stereo codec
Realtek 2-channel ALC221 codec
Audio I/O ports
Front microphone-In (150-K ohm Input Impedance)
Internal speaker amplifier
1.5-W amplifier for the internal speaker only. External speakers must be powered externally. Rear Line-in audio port is re-taskable as either Line-in or Microphone-In.
Multi-streaming capable
Multi-streaming can be enabled in the Realtek control panel to allow independent audio streams to be sent to/from the front and rear jacks.
Sampling
8 kHz - 192 kHz
Wavetable syntheses
Yes - Uses OS soft wavetable
Analog audio
Yes
# of channels on Line-Out
Stereo (Left & Right channels)
Internal speaker
Yes
External speaker jack
Yes
Full duplex
Yes
Graphic specifications
Intel HD graphics
Specification
VGA controller
Integrated
DisplayPort
Multimode capable; supports HDCP, Display Port Audio (2 streams), HBR2 link rates and Multi-Stream Technology for a maximum of 3 displays (including the integrated panel)
Memory
  • Intel graphics do not have dedicated memory but utilizes some of the computer's system memory
  • 32MB is pre-allocated for graphics use at system boot time
Maximum graphics memory
  • Microsoft Windows 7: Up to 1.7GB
  • Windows 8: Up to 1.8GB
Maximum color depth
32 bits/pixel
Graphics/Video API support
4th Generation Core processors
AMD Radeon HD 7650A graphics card
Specification
Form factor
MXM 3.0
Graphics controller
AMD Radeon HD 7650A
Core clock
600 MHz
Memory clock
800 MHz
Memory
2GB, DDR3, 128-bit wide
Bus type
MXM
Max. power
35 W
Power source support
12 V and 19 V
3D API support
DX11, SMS
HDCP support
Yes
Display max. resolution
  • Digital: 2560 x 1600
  • Analog: 2048 x 1536
Supported graphics APIs
DX11, OpenGL, full 1080p BD (H264) playback in hardware, Multi-Stream DisplayPort support
NVIDIA NVS 310 graphics card
Specification
Form factor (H x L)
Low profile: 6.89 x 15.62 cm (2.713 × 6.15 in)
Graphics controller
NVIDIA NVS 310
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14 GB/s
Max. power
19.5 W
Up to 2560 x 1600 (digital display) per display
Display output
Up to 2 displays
Max power
19.5 W
NVIDIA GeForce GT630 graphics card
Specification
Form factor
PCIe x16 card
Graphics controller
NVIDIA Kepler Architecture GPU
Core clock
875 MHz
Memory clock
891 MHz
Memory cize
2GB DDR3 128 bit
Memory bandwidth
28.5 GB/s
Display support
Integrated 400-MHz Random Access Memory Digital-to-Analog Converter (RAMDAC)
NVIDIA NVS 315 1GB PCIe x 16 graphics card
Specification
Form factor
Low profile: 2.713 × 6.15 in
Graphics controller
NVIDIA NVS 315
Memory clock
875 MHz
Memory size
512MB DDR3
Memory bandwidth
14 GB/s
Connectors
DMS-59, with support for dual VGA, dual DVI or dual Display Port with the appropriate adapter cable
Up to 2048 x 1536 VGA; 1920 x 1200 DVI; 2560 x 1600 DisplayPort
AMD Radeon HD 8350 1GB PCie x16 DH graphics card
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8350
Core clock
GPU engine operates at 523 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
875 MHz
HDCP support
Yes
  • Digital: 1920 x 1200
AMD Radeon HD 8490 1GB PCie x16 graphics card
Specification
Form factor
PCie x16
Graphics controller
AMD Radeon HD 8490
Core clock
GPU engine operates at 875 MHz
Memory
1GB, DDR3, SDRAM
Memory clock
900 MHz
HDCP support
Yes
Hard Disk Drive (HDD) specifications
HP 1TB 10K-rpm SATA 6.0 Gb/s 3.5-inch HDD
Specification
Capacity
1TB
Rotational speed
10,000 rpm
Interface
Serial ATA (6.0 Gb/s)
Synchronous transfer rate (maximum)
Up to 600 MB/s
Buffer size
64MB
Cache
Adaptive
Seek time (typical reads, includes controller overhead, including settling)
  • Single track: 1.2 ms
  • Average: 3.6 ms
  • Full-stroke: 9.0 ms
Height (nominal)
1.53 mm (0.6 in)
Width (nominal)
  • Media diameter: 63.6 mm (2.5 in)
  • Physical size: 69.9 mm (2.75 in)
Operating temperature
5° to 55°C (41° to 131°F)
HP 500GB 10K-rpm SATA 6.0 Gb/s 3.5-inch HDD
Specification
Capacity
500GB
Rotational speed
10,000 rpm
Interface
Synchronous transfer rate (Maximum)
Up to 600 MB/s
Buffer size
64MB
Cache
Adaptive
  • Average: 3.6 ms
Height (nominal)
1.53 mm (0.6 in)
Weigt (nominal)
HP 500GB 7200-rpm SATA 2.5-inch Self-Encrypting (SED) HDD
Specification
Capacity
320,072,933,376 bytes
Rotational speed
7,200 rpm
Drive type
SED with SATA interface
Interface
Serial ATA 2.0 (6.0 Gb/s)
Segmented buffer with write cache
32768KB - A portion of buffer capacity used for firmware
Number of sectors
976,773,168
Seek time
  • Single track: 1.0 ms
  • Average: 13 ms
  • Full-stroke: 25 ms
Media diameter
63.5 mm (2.5 in)
Height (nominal)
6.8 mm (0.267 in), ± 0.2 mm
Width
69.85 mm (2.75 in), ± 0.2 mm
Length
100.2 mm (3.945 in), ±0.25 mm
95 g (3.35 oz) (max)
HP 500GB 7.2K SATA 6.0 Gb/s 2.5-inch HDD
Specification
Capacity
500,107,862,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
16MB
Logical blocks
976,773,168
Seek time
  • Single track: 2.0 ms
  • Average: 11 ms
Height (nominal)
9.5 mm (0.374 in)
Width (nominal)
  • Media diameter: 63.5 mm (2.5 in)
  • Physical size: 70 mm (2.75 in)
HP 1TB SATA 6G 2.5-inch 8GB Solid State Hybrid Drive (SSHD)
Specification
Formatted capacity
1TB
Spindle speed
5,400 rpm +/- 0.2%
Drive type
SSHD technology with NAND flash
Interface
Serial ATA (SATA)
Cache buffer
64MB
NAND flash Commercial Multilevel Cell (cMLC)
8GB
Number of sectors
976,773,168
Seek time (typical reads)
  • Average: 12 ms
Drive type
SSHD technology with NAND Flash
Height
9.5 +/- 0.2 mm (0.374 +/- 0.008 in)
Width
69.85 +/- 0.25 mm (2.750 +/- 0.010 in)
Length
100.35 +0.20/-0.25 mm (3.951 +0.008/-0.010 in)
115 g (0.254 lb) (max)
0° to 60°C (32° to 140°F)
HP 120GB SSD
Specification
Unformatted capacity
120 GB
Architecture
Multi Level Cell (MLC) NAND Flash with wear leveling 10 channel controller
Interface
Serial ATA 2.0 (3.0 Gb/s)
Dimensions (W x H x D)
6.98 x 0.95 x 10.2 cm (2.74 x 0.37 x 4 in)
80 g (0.18 lb)
Bandwidth performance
  • Sustained Sequential Read: Up to 250 MB/s
  • Sustained Sequential Write: Up to 70 MB/s
  • Random Read: Up to 35K IOPs
  • Random Write: Up to 6.6K IOPs
Latency
  • Read: 65 ms
  • Write: 85 ms
Power
  • DC power requirement: 5 V dc 5%-100 mV ripple p-p
  • Total power consumption: 0.15 W (active); 0.075 W (idle)
Useful drive life
35TB written, up to 20GB/day for 5 years
Environmental (all conditions, non-condensing)
  • Operating temperature:: 0° to 70°C (32° to 158°F)
  • Relative humidity: 5% to 95%
  • Maximum wet bulb temperature (operating): 29°C (84°F)
  • Shock: 1,500G/0.5 ms
HP 128GB SSD
Specification
128GB
Architecture
Interface
SATA 6 GB/s
6.985 x 0.7 x 10.05 cm (2.75 x 0.276 x 3.96 in)
73 g (0.16 lb)
  • Sustained Sequential Read: Up to 450 MB/s
  • Sustained Sequential Write: Up to 260 MB/s
  • Random Read: Up to 46K IOPs
  • Random Write: Up to 56K IOPs
Latency
  • Read: 55 ms
  • Write: 55 ms
Power
  • DC power requirement: Min 4.5 V; Max 5.5 V
  • Total power consumption: 160 mW (Active) ; < 85 mW (Idle)
Useful Drive Life
1.2 million device hours
Environmental
  • Shock: 1,500G/1.0 ms
Regulations
UL, CSA, EN 60950-2000, CISPR Pub 22 Class B, CNS 13438, AS/NZSCISPR 22:2002 Class B, Korea KCC, CE Mark
Option kit contents
HP 128GB SSD, documentation, 3.5-inch bay adapter bracket, 3.5-inch bay adapter bracket screws, SATA cable
HP 160GB SSD
Specification
Unformatted Capacity
160GB
Architecture
Interface
SATA 3 GB/sec
80 g (0.18 lb)
Bandwidth Performance
  • Random Read (4KB): Up to 70K IOPs
  • Random Write (4KB): Up to 35K IOPs
Latency
  • Read: 65 ms
  • Write: 85 ms
Power
  • Total power consumption: 0.15 W Active); 0.075 W (Idle)
Useful drive life
35TB written, up to 20 GB/day for 5 years
Environmental
Regulations
UL, CSA, EN 60950-2000, CISPR Pub 22 Class B, CNS 13438, AS/NZS CISPR 22:2002 Class B, Korea KCC, CE Mark
HP 256GB SATA 2.5-inch SED SSD
Specification
256,186,209,271 bytes
Architecture
SED SSD with 25 nm MLC NAND Flash and SATA interface
Interface
NAND flash
Height
7 mm (0.275 in)
Width
69.85 mm (2.75 in)
Length
100.5 mm (3.95 in)
73 g (0.161 lb)
  • Random Read (4KB): Up to 46K IOPs
  • Random Write (4KB): Up to 56K IOPs
Latency
  • Read: 55 ms
  • Write: 55 ms
Power
SATA power consumption: 160 mW (active average); < 85 mW (idle average)
Useful drive life
72TB written, up to 40 GB/day for 5 years
Environmental
HP 500GB 7.2K-rpm SATA 6.0 Gb/s 3.5-inch HDD
Specification
Capacity
Rotational speed
7,200 rpm
Interface
Serial ATA 3.0 (6.0 Gb/s)
Buffer size
16MB
Logical blocks
976,773,168
  • Average: 11 ms
  • Full-stroke: 21 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
  • Media diameter: 8.89 cm (3.5 in)
  • Physical size: 10.2 cm (4 in)
HP 1TB 7.2K-rpm SATA 6.0 Gb/s 3.5-inch HDD
Specification
Capacity
1,000,204,886,016 bytes
Rotational speed
7,200 rpm
Interface
Buffer size
32MB
Logical blocks
1.95E+09
  • Average: 11 ms
Height (nominal)
2.54 cm (1 in)
Width (nominal)
HP 2TB 7.2K-rpm SATA 6.0 Gb/s 3.5-inch HDD
Specification
Capacity
2TB
Rotational speed
7,200 rpm
Interface
SATA 6Gb/s NCQ
Buffer Size
64MB
Cache, multisegmented (MB)
1.95E+09
Seek time (average)
  • Read: < 8.5 ms
  • Write: <9.5 ms
Height
26.11 mm (1.028 in)
Width
101.6 mm (4.0 in)
Depth
146.99 mm (5.787 in)
626 g (1.38 lb)
Input/Output devices
HP USB keyboard
Specification
Physical characteristics
Keys
104, 105, 106, 107, 109 layout (depending upon country)
Dimensions (L x W x H)
46.03 x 16.43 x 2.44 cm (18.12 x 6.47 x 0.96 in)
0.9 kg (2 lb)
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
50 mA maximum (with three LEDs On)
System interface
USB Type A plug connector
ESD
CE level 4, 15 kV air discharge
EMI - RFI
Conforms to FCC rules for a Class B computing device
Microsoft PC 99 - 2001
Functionally compliant
Mechanical
Keycaps
Low-profile design
Switch actuation
55 g nominal peak force with tactile feedback
Switch life
20 million keystrokes (using Hasco modified tester)
Switch type
Contamination-resistant switch membrane
Key-leveling mechanisms
For all double-wide and greater-length keys
Cable length
1.8 m (6 ft)
Mechanically compliant
Acoustics
43-dBA maximum sound pressure level
Environmental
10° to 50°C (50° to 122°F)
Non-operating temperature
-30° to 60°C (-22° to 140°F)
Operating humidity
10% to 90% (non-condensing at ambient)
Non-operating humidity
20% to 80% (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
2 g peak acceleration
Non-operating vibration
4 g peak acceleration
Drop (out of box)
66 cm (26 in) on carpet, six-drop sequence
Drop (in box)
76.2 cm (30 in) on concrete, 16-drop sequence
Approvals
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC
Ergonomic compliance
UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, KC
Kit contents
Keyboard
Installation guide
Warranty card
Safety and comfort guide
HP PS/2 keyboard
Specification
Keys
Dimensions
46.28 x 16.43 x 2.79 cm (18.22 x 6.47 x 1.1 in)
(L x W x H)
0.9 kg (2 lb) minimum
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
50-mA maximum (with three LEDs On)
System interface
PS/2 6-pin mini din connector
ESD
CE level 4, 15-kV air discharge
EMI - RFI
Mechanical
Keycaps
Low-profile design
Switch actuation
55-g nominal peak force with tactile feedback
Switch life
Switch type
Cable length
1.8 m (6 ft)
Acoustics
50-dBA maximum sound pressure level
Environmental
0° to 40°C (32° to 104°F)
-30° to 65°C (-22° to 149°F)
Operating humidity
15% to 80% (non-condensing at ambient)
15% to 90% (non-condensing at ambient)
Operating shock
N/A
Non-operating shock
2.9 ms (65 in), six surface; 30 g 266 in/s; 50 g 266 in/s six surface
Operating vibration
2-g peak acceleration
Starting at 5 Hz, vary the frequency of vibration from 5 to 500 Hz and back to 5 Hz at a Logarithmic sweep rate of 1 octave per minute.
Drop (out of box)
66 cm (26 in) on carpet, 6-drop sequence
Drop (in box)
76 cm (29.93 in) on concrete, 16-drop sequence
Approvals
CUL, ICES-003 Class B, FCC, CE Mark,TUV GS, VCCI, BSMI, C-Tick, KC
ANSI HFS 100, ISO 9241-4, and TUVGS
HP USB Smart Card (CCID) keyboard
Specification
Keys
46.3 x 16.1 x 3.3 cm (18.2 x 6.3 x 1.3 in)
Electrical
Operating voltage
+ 5 V dc ± 5%
Power consumption
100 mA maximum (with three LEDs On)
System interface
ESD
EMI - RFI
Mechanical
Languages
30+ available
Keycaps
Standard design
Switch actuation
Switch life
Switch type
Cable length
1.8 m (6 ft)
Acoustics
Environmental
Operating humidity
Operating shock
40-g, six surfaces
Non-operating shock
80-g, six surfaces
Operating vibration
4-g peak acceleration
Drop (out of box)
Drop (in box)
107 cm (42 in) on concrete, 16-drop sequence
Support
All ISO 7816 smart cards
Interface
Reads from and writes to all ISO7816-1, 2, 3, 4 memory and microprocessor smart cards (T=0, T=1)
SCM STCIII
Standard APIs supported
PC/SC, EMV2000, CT-API
Power
USB Port Short circuit detection (protects smart card and reader)
SmartCard function
Power consumption
100 mA maximum draw
Communication
  • From card 9600 bps to 330,000 bps
  • From computer 12 Mbps (USB transfer speed)
Landing mechanism
  • Contact device: Friction contact
  • Card insertions rating: Up to 100,000 insertion cycles
Interface modes
CCID protocol
Reader performance interface
USB connection
Electro-magnetic standards
  • Europe: 2004/108/EC
  • USA: USAFCC part 15
Approvals
CE-Mark, UL, CSA, FCC, CE Mark, TUV, TUV GS, VCCI, BSMI, C-Tick, MIC, EMV2000, USB-IF
ISO 9241-4, TUVGS
Kit contents
Keyboard, I/O Security and Documentation CD, warranty card
HP USB PS/2 washable keyboard
Specification
Keys
104 (US) layout or 105 (EU) layout – depending upon country
449 x 168 x 35 mm (17.67x 6.62 x 1.38 in)
0.77 kg (1.7 lb) minimum
Electrical
Operating voltage
+ 5 V dc ±5%
Power consumption
System interface
ESD
EMI - RFI
Mechanical
Keycaps
Stepped -profile design
Switch actuation
Switch life
Switch type
Cable length
2.2 m (7 ft)
Environmental
Acoustics
Operating humidity
10% to 95% (non-condensing at ambient)
Operating shock
40 g, six surfaces
Non-operating shock
80 g, six surfaces
Operating vibration
Drop (out of box)
Drop (in box)
Operating system support
Windows 7, Windows Vista, Windows XP Professional
Approvals
UL, cUL, FCC, CE, TUV GS, VCCI, BSMI, C-Tick, KCC, USB-IF, WHQL, EN/IEC 60601-1, IP66/NEMA4X
HP Wireless keyboard and mouse specifications
Specification
Keyboard
Dimensions (H x L x W)
27.87 x 460.3 x 164.3 mm (1.09 x 18.1 x 6.47 in)
Weight - without Two AA Alkaline Batteries
880 g (1.94 lb)
Mouse
37 x 115 x 62.9 mm (1.46 x 4.53 x 2.47 in)
67 g (0.15 lb)
Receiver
8.4 x 45.5 x 18.4 mm (0.33 x 1.79 x 0.72 in)
5.9 g (0.21 oz)
Cable length - minimum
1.8 m (6 ft)
Range
10 m (32.8 ft)
System requirements1
  • Windows 7 Home Basic, Windows 7 Home Premium, Windows 7 Professional Edition 32, Windows 7 Professional Edition 64, Windows 7 Ultimate Edition 32, Windows 7 Ultimate Edition 64 Windows Vista or Windows XP
  • Available USB port for the receiver
  • CD-ROM Drive
Approvals
Product Safety
UL; CSA /TUV (Europe only); CE Mark; CB Report
Ergonomics
ANSI; ISO (Europe only); GS Mark (Germany only)
EMC
FCC; CE; ACA (-tick); BSMI; KC ; VCCI
CE Mark
EN 55022:2010; EN 55024; EN 301489-1; EN 61000
Design Guidelines for PCs
PC 99 - connector overmold colors; PC 2001 - full functionality
Telecom
All local telecom requirements and approvals for intended markets
USA
FCC Title 47 CFR, Par 15, Subpart C; other local requirements
Country Support
US, Belgium, Switzerland, Spain, Denmark, Netherlands, France, Germany, Italy, Portugal, Sweden, Norway, Finland, UK, Poland, Czech Republic, Turkey, Greece, Austria, Bulgaria, Cyprus, Estonia, Hungary, Ireland, Latvia, Lithuania, Luxemburg, Malta, Romania, Slovakia, Slovenia, Vietnam, HK, Australia, NZ, Malaysia, Singapore, Indonesia, Philippines, Thailand, Canada, China, Japan, Korea, Taiwan, India, Venezuela, Ecuador, Russia, Ukraine, Israel, Croatia, United Arab Emirates, Peru, Brazil, Chile, Argentina, Mexico, South Africa, and up to 193 countries worldwide.
1: This system may require upgraded and/or separately purchased hardware and/or a DVD drive to install the Windows 7 software and take full advantage of Windows 7 functionality. See http://www.microsoft.com/windows/windows-7/ for details.
HP USB PS/2 washable mouse specifications
Specification
3.95 x 6.21 x 11.7 cm (1.56 x 2.44 x 4.61 in)
126 g (4.44 oz)
Environmental
0° to 40°C (-32° to 104°F)
-20° to 60°C (-4° to 140°F)
Operating humidity
10% to 90% non-condensing
Operating shock
40 g, 6 surfaces
Non-operating shock
80 g, 6 surfaces
Operating vibration
Drop (out of box)
80 cm height onto asphalt tile over concrete or equivalent, 5-drop in 5 direction except the cable face
Electrical
Operating voltage
5 V dc ± 10%
Power consumption
100 mA
System consumption
PS/2 mini-din connector or USB
ESD
CE level 2, 8 kV air discharge
EMI-RFI
Microsoft PC99 – 2001
Mechanical
Resolution
1000 ± 20% DPI
Tracking speed
35.56 cm/s (14 in/s) maximum
Acceleration
2 g
Switch actuation
70 g nominal peak force
Switch life
3,000,000 operations (using Hasco modified tester)
Switch type
Low force micro-switches
Cable length
8.8 ft total 70 cm+ 2m extension
Scroll wheel
Width
6 mm
Diameter
25.4 mm (1 in)
Maximum rotation speed
48 rats/sec
Switch type
Light force micro-switch
Switch life
3 million operations
Mechanical life
Minimum 200,000 revolutions
Regulatory approvals
Compliant
FCC, CE Mark, ICES-003-B, IP66/NEMA4X
HP PS/2 mouse
3.70 x 6.29 x 11.50 cm (1.46 x 2.48 x 4.53 in)
3.53 oz (100g; +10g/- 5 g)
Operating humidity
10% to 90% (non condensing at ambient)
Operating shock
40 g, 6 surfaces
Non-operating shock
80 g, 6 surfaces
Operating vibration
Drop (out of box)
Operating voltage
5 V dc ± 10%
Power consumption
100 mA
System consumption
ESD
EMI-RFI
Microsoft PC99 - 2001
Resolution
800 DPI
Tracking speed
10 in/s (25.4 cm/s) maximum
Acceleration
±15%
Switch actuation
65±20 gf
Switch life
Switch type
Tracking mechanism life
80 km
Cable length
1.8 m (6 ft)
Width
6 mm
Diameter
22.5 ± 0.2 mm
Maximum rotation force
50 gf-cm
Switch type
Switch life
1 million operations
Mechanical life
Regulatory Approvals
UL/cUL, FCC, CE Mark, TUV/GS, VCCI, KCC, BSMI, C-Tick
HP USB mouse
Specification
3.8 x 11.6 x 6.3 cm (1.5 x 4.5 x 2.5 in)
0.10 kg (0.22 lb)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
HP USB 1000 dpi laser mouse
Specification
37.3 x 114.97 x 62.86 mm (1.47 x 4.53 x 2.47 in)
102 g (3.360 oz)
Cable length
180 cm (70.9 in)
System requirements
Available USB port
Environmental
Operating humidity
Mechanical
Resolution
1000 dpi
Tracking speed
45 cm/s
Cable length
180 cm (70.9 in)
Removable storage specifications
HP Slim SuperMulti DVD Writer Drive
Specification
Height
12.7 mm
Orientation
Either horizontal or vertical
Interface type
SATA/ATAPI
Disc recording capacity
Up to 8.5GB DL or 4.7GB standard
128 x 13.6 x 129 mm (5.0 x 0.5 x 5.0 in)
Weight (max)
190 g (0.42 lb)
Access time
  • Random:
    • DVD: < 140 ms (typical)
    • CD: < 125 ms (typical)
  • Full stroke:
    • DVD: < 250 ms (seek)
    • CD: < 210 ms (seek)
  • Stop time: < 4 s
Power
  • Source: Four-pin, DC power receptacle
    • 5 V dc ± 5%-100 mV ripple p-p
    • 12 V dc ± 5%-200 mV ripple p-p
  • DC current:
    • 5 V dc (< 1000 mA typical, 1600 mA maximum)
    • 12 V dc (< 600 mA typical, 1400 mA maximum)
  • Total drive power (standby mode): 2.5 W
Audio output
  • Signal-to-Noise ratio: 74 dB
  • Channel separation: 65 dB
Environmental conditions (operating - non-condensing)
  • Temperature: 5° to 50°C (41° to 122°F)
  • Relative humidity: 10% to 90%
  • Maximum wet bulb temperature: 30°C (86°F)
HP slim Blu-ray BDXL drive
Specification
Height
12.7 mm slim tray-load
Orientation
Interface type
SATA/ATAPI
Disc capacity
Up to 128GB QL, 100GB TL, 50GB DL or 25GB standard SL
128 x 12.7 x 127 mm (5.04 x 0.5 x 5.0 in)
Weight (max)
Up to 170 g (0.37 lb) without bezel
Access time
  • Random:
    • BD-ROM: 205 ms (typical), DVD-ROM: 185 ms (typical)
    • CD-ROM: 165 ms (typical)
  • Full stroke:
    • BD-ROM: 350 ms (typical), DVD-ROM: 345 ms (typical)
    • CD-ROM: 340 ms (typical)
Power
  • Source: Slimline SATA DC power receptacle
  • DC power requirement: 5 V dc ± 5%-100 mV ripple p-p
  • DC current: 12 V dc - 1200 mA typical, 2000 mA maximum
Audio output
HP slim DVD-ROM drive
Specification
Height
12.7 mm
Interface type
SATA/ATAPI
Weight (max)
190 g (0.42 lb) without bezel
Access time
  • Random:
    • DVD: < 140 ms (typical), CD: < 125 ms (typical)
    • CD: < 250 ms (seek), CD: < 210 ms (seek)
Power
  • DC current: 5 V dc - < 1000 mA typical, < 1600 mA maximum
  • Total drive power (standby mode): < 2.5 W
Audio output
  • Line-Out: 0.7 VRMS
  • Relative humidity: 5% to 85%
  • Maximum wet bulb temperature (operating): 30°C (86°F)
Communication specifications
Intel I1217LM GbE Network Connection
Specification
Connector
RJ-45
System interface
Integrated on PCA
Controller
Intel I217LM GbE platform LAN connect networking controller
Memory
24KB FIFO packet buffer memory
Data rates supported
10/100/1000 Mb/s
IEEE Compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3ab
  • 802.3az
  • 802.3u
Bus architecture
PCI Express and SMBus
Data transfer mode
PCIe-based interface for active state operation (S0 state) and SMBus for host and management traffic (Sx low power state)
Power requirement
  • Requires 3.3 V and 0.9 V or just 3.3 V with integrated regulators
  • Power consumption 0.733 W
Boot ROM support
Yes
Network transfer mode
  • Full-duplex
  • Half-duplex (not supported for the 1000BASE-T transceiver)
Network transfer rate
  • 10BASE-T (half-duplex) 10 Mb/s
  • 10BASE-T (full-duplex) 20 Mb/s
  • 100BASE-TX (half-duplex) 100 Mb/s
  • 100BASE-TX (full-duplex) 200 Mb/s
  • 1000BASE-T (full-duplex) 2000 Mb/s
Environmental
  • Operating temperature: 0° to 85°C (32° to 185°F)
  • Operating humidity: 60% RH
Management
WOL, auto MDI crossover, PXE, Muti-port teaming, RSS, Advanced cable diagnostic
Alerting
ASF 2.0 support; AMT 9.0 support
Intel Ethernet I210-T1 Gigabit Network adapter
Specification
Connector
RJ-45
System Interface
PCI Express x1
Controller
Intel I210 Gigabit Ethernet Controller
Memory
Integrated Dual 48K configurable transmit receive FIFO Buffers
10/100/1000 Mb/s
IEEE Compliance
  • 802.1P
  • 802.1Q
  • 802.2
  • 802.3
  • 802.3AB
  • 802.3x flow control
  • 802.3u
Bus architecture
PCI-E 2.1
Data path width
X1, 250 MB/s, Bi-directional interface
Data transfer mode
Bus-master DMA
Hardware certifications
FCC, B, CE, TUV-c, TUVus Mark Canada and United States, TUV-GS Mark for European Union
Power requirement
Aux 3.3 V, 3.0-W in 1000 base-T and 1.0- W in 100 Base-T
Boot ROM support
Yes
Network Transfer Rate
Environmental
  • Operating temperature: 0° to 55°C (32° to 131°F)
  • Operating humidity: 85% at 55°C (131°F)
Management
WOL, PXE, DMI, WFM 2.0
Intel Centrino Advance-N 6205 Wireless Network Interface Connection
Wireless LAN standards
  • IEEE 802.11a/b/g/n
  • IEEE 802.11 e, 802.11i, 802.11d, 802.11d, 802.11h
Interoperability
  • Wi-Fi certified (802.11a/b/g/n WMM, WPA, WPA2 and WPS)
  • Tested with wireless access points from several major manufacturers
  • OS compatible with Microsoft Windows, Win7 and XP
  • Cisco Compatible Extensions Program compliant (802.11a/b/g only) with Microsoft Windows XP and Windows 7
Frequency band
2.4 GHz and 5 GHz
Antenna Structure
2 transmit; 2 receive (2 x 2)
Data Rates
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 66 possible data rates, ranging from 6 Mbps to 300 Mbps, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES (support for key sizes of 128bits), TKIP, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP, MSCHAP, PEAP-MSCHAPv2, LEAP, EAP-FAST, EAP-SIM, EAP-AKA PAP, CHAP, TLS, GTC
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media Access Protocol
CSMA/CA (Collision Avoidance) with ACK
Network Architecture Models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
  • Intel My Wifi Technology (iPAN)
Roaming
Provide seamless roaming between like access points (same frequency band)
Output power (for CCK)
15 dBm
Output power (for OFDM; power varies by data rate)
15 dBm
Power consumption
  • Transmit: 2.3 W (average, with one spatial streams)
  • Receive: 1.9 W (average with two receive chains)
  • Idle mode: 30 mW to 40 mW (average)
  • Radio Off: 20 mW (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Antenna connections
3 U.FL type connectors, 50 ohm nominal impedance
4.0 g (0.013 lb)
Dimensions
26.8 x 30.0 mm (1.1 x 1.2 in)
Operating Voltage
3.3 V +/- 9%, 1.5 V +/- 5%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
Power supply specifications
Specification
Standard efficiency
320 W active PFC
High efficiency1
Integrated graphics:
  • 320 W active PFC
  • 87/90/87% efficient at 20/50/100% load
Operating voltage range
90 - 264 V ac
Rated voltage range
100 - 240 V ac
Rated line frequency
50/60 Hz
Operating line frequency   range
47 - 63 Hz
Rated input current
5.5 A
Rated input current with   energy
5.5 A
Current leakage   (NFPA 99)
< 450=> 275 µA
Power supply fan
92 mm variable speed
Power cord length
1.83 m (6 ft)
1: High efficiency power supply is a requirement for ENERGY STAR qualification in conjunction with a select range of processors and modules.
Software overview
Feature
Operating Systems
Preinstalled
  • Windows 8 Pro (64-bit)
  • Windows 8 (64-bit)
  • Windows 7 Ultimate (32-bit)
  • Windows 7 Ultimate (64-bit)
  • Windows 7 Professional (32-bit)
  • Windows 7 Professional (64-bit)
  • Windows 7 Professional (32-bit) (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Professional (64-bit) (available through downgrade rights from Windows 8 Pro)
  • Windows 7 Home Premium (32-bit)
  • Windows 7 Home Premium (64-bit)
  • FreeDOS 2.0
  • Novell SUSE Linux Enterprise Desktop 11
Supported
  • Windows 7 Enterprise (32-bit or 64-bit)
  • Windows 8 Enterprise (64-bit)
Limited support
Windows XP Professional (32-bit)
Certified
  • Red Hat Enterprise Linux 64
Test & Document1
  • Windows Vista Enterprise (32-bit or 64-bit)
  • Windows Vista Professional (32-bit or 64-bit)
1: For all Test & Document operating systems HP will perform functional testing of the Operating System on the HP business PC platform. Any issues found will be documented in an Engineering Advisory and/or Service Advisory and posted to HP. HP will not develop or qualify any drivers or perform any integration testing.
