This document applies to HP Pavilion dm1-4xxx series notebook computers.
warning:The edges of metal panels can cut skin. Be careful not to slide skin along any interior metal edge of the computer.
warning:Before starting, power off the computer and wait for components to cool before starting these procedures.
caution:This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
note:For best quality on dial-up connections, wait until the video has fully loaded before viewing.
note:The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion dm1-4xxx Series PCs.
warning:Make sure the computer is disconnected from power before starting.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Step 2
Remove the service cover.
For more information about removing the service cover, refer to the HP support document Removing and Replacing the Service Cover.
Step 3
Use the black tab on the hard disk drive adapter cable to disconnect the cable from its connector.
Step 4
Lift the hard drive adapter cable out of the routing channel.
Step 5
Remove the Phillips-head screw that secures the hard disk drive bracket to the base enclosure.
Save the screw for hard drive replacement.
Step 6
Grasp the Mylar tab on the left of the hard disk drive assembly and lift the left side of the hard disk drive assembly up.
Step 7
Slide the hard disk drive assembly out of the hard disk drive bay.
Step 8
Remove the two rubber isolators from the hard disk drive bracket.
Step 9
Disconnect the hard drive cable from the drive.
Step 10
Remove the four Phillips-head screws (two on each side) that secure the hard disk drive bracket to the hard disk drive.
Save the screws for bracket replacement.
Step 11
Remove the hard disk drive bracket from the hard disk drive.
Step 12
Place the hard drive in an anti-static bag.
Step 1
Place the hard disk drive with the label facing down and align the hard disk drive bracket onto the hard disk drive.
Step 2
Replace the four screws that secure the hard drive bracket to the hard drive.
Step 3
Connect the hard disk drive adapter cable into its connector on the hard disk drive.
Step 4
Replace the two rubber isolators onto the hard disk drive bracket.
Step 5
Align the right side of the hard disk drive assembly into the hard disk drive bay.
Step 6
Lower the left side of the hard disk drive assembly into position in the hard disk drive bay.
Step 7
Replace the Phillips-head screw that secures the hard disk drive bracket to the base enclosure.
Step 8
Connect the hard disk drive cable to the system board.
Step 9
Route the hard disk drive adapter cable through the routing channel on the base enclosure.
Step 10
Replace the service cover.
Step 11
Replace the battery.
For more information about replacing the battery, refer to the HP support document Removing and Replacing the Battery.
