    Windows 11 Upgrade Guide
HP Z Display Z22i 21.5-inch IPS LED Backlit Monitor - Specifications
Product description
Product features
Feature
Display size
54.61 cm (21.5 in)
Swivel
360°
Input signal
  • One VGA connector
  • One DVI connector
  • One DisplayPort connector (cable inclusion varies by region)
Display moving angle
Tilt: –5° to 30°
Type
IPS LCD
Panel specifications
Feature
Display size
54.61 cm wide screen (21.5 in wide screen)
Tilt
-5° to 30°
Swivel
360°
Performance
Specification
Maximum graphic resolution
  • 1920 x 1080 (60 Hz) analog input
  • 1920 x 1080 (60 Hz) digital input
Optimum graphic resolution
Text mode
720 x 400
Horizontal frequency
24 to 94 kHz
Vertical refresh rate
50 to 76 Hz
Physical specifications
Feature
Display type
IPS LCD
Maximum weight (Unpacked)
5.7 kg (12.54 lbs)
Electrical specifications
Specification
Power source
90 – 265 V ac at 45 - 63 Hz
Measured power consumption
  • Full power: 33 watts
  • Typical settings: 29 watts
  • Sleep: 0.5 watts
  • Switch Off: 0.5 watts
Environmental specifications
Specification
Operating temperature
5° to 35° C (41° to 95° F)
Storage temperature
-20° to 60° C (-4° to 140° F)
Relative humidity
20% to 80%
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
