Document ID: c03783836
Version: 1
HP ProBook Notebook PCs - The Computer Locks Up When Resuming From Hibernation After Switching From Discrete to Integrated Graphics
Release date : 31-May-2013
Last updated : 25-Jun-2013
DESCRIPTION
Using the AMD Catalyst Control Center to switch the graphics from the discrete graphics processing unit (dGPU) to the integrated graphics processing unit (iGPU) may cause the computer to lock up when trying to resume from the Suspended or Hibernation states.
sourceInformation
SCOPE
Computers:
  • HP ProBook 440 G0 Notebook PC
  • HP ProBook 445 G1 Notebook PC
  • HP ProBook 450 G0 Notebook PC
  • HP ProBook 455 G1 Notebook PC
  • HP ProBook 470 G0 Notebook PC
Operating System:
  • SUSE Linux Enterprise Desktop 11
RESOLUTION
Use the Computer Setup (BIOS) menu instead of the AMD Catalyst Control Center to disable the dGPU. Complete the following procedure:
  1. Turn on or restart the computer, and then press esc while the "Press the ESC key for Startup Menu" message is displayed at the bottom of the screen.
  2. Press F10 to enter Computer Setup.
  3. Select System Configuration.
  4. Select Device Configuration.
  5. Uncheck Switchable Graphics.
  6. Save and exit the BIOS.
Hardware platforms affected : HP ProBook 440 G0 Notebook PC, HP ProBook 445 G1 Notebook PC, HP ProBook 450 G0 Notebook PC, HP ProBook 455 G1 Notebook PC, HP ProBook 470 G0 Notebook PC
Support Communication Cross Reference ID : IA03783836
Country: Flag Thailand
