A 'Carriage Jam' Message Displays for HP ENVY 4500 e-All-in-One and HP Deskjet Ink Advantage 3540 e-All-in-One Printer Series
Issue
A 'Carriage Jam: Clear carriage jam' message displays on the printer control panel. The carriage, which holds the cartridges, stalls in the printer. A paper jam might have occurred previously.
You might also experience the following symptoms:
  • The printer does not print.
  • The print job stops unexpectedly.
Important: You must follow these solutions in the order presented to resolve the issue.
The following video demonstrates how to clear a carriage jam.
This video shows the HP ENVY 4500 printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Solution one: Make sure that the carriage can move freely
Follow these steps to make sure that the carriage moves freely across the width of the printer.
  1. Press the Power button to turn on the printer, if it is not already on.
  2. Open the cartridge access door.
    The carriage might try to move into the access area. If it does, allow it to move to that position.
    Image: Open the cartridge access door.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
      warning:
    To avoid the risk of electrical shock, you must unplug the power cord before moving the carriage by hand and resetting the paper feed mechanism.
  4. Check for, and then remove, any loose paper or objects that might be restricting the carriage.
    Use a flashlight to thoroughly check for torn pieces of paper that might remain inside the printer. If any torn pieces of paper remain inside the printer, more jams might occur.
  5. Reach into the cartridge access area, and then manually move the carriage.
    • If the carriage is stuck on the right side of the printer, move the carriage to the left side of the printer.
    • If the carriage is stuck on the left side of the printer, move the carriage to the right side of the printer.
    • If the carriage is stuck in the middle of the printer, move the carriage to the right side of the printer.
  6. Remove any additional loose paper or objects.
  7. Make sure that the carriage can move freely across the width of the printer by gently pushing the carriage to the left, and then to the right.
  8. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door.
  9. Reconnect the power cord to the rear of the printer.
  10. Press the Power button to turn on the printer.
  11. Touch OK to clear any messages on the printer control panel.
Step two: Print a Printer Status Report
Print a test page to make sure that the hardware functions correctly.
  1. On the printer control panel, press the Down Arrow () to select Tools, and then press OK.
  2. Press the Down Arrow () to select Printer Status Report, and then press OK. The printer prints the test page.
    Figure : Example of a Printer Status Report
    Image: Example of a Printer Status Report
  • If these steps resolved the issue and the test page prints, you can stop troubleshooting.
  • If these steps did not resolve the issue or the test page did not print, continue to the next solution.
Solution two: Remove and reinsert the cartridges
Improper placement or installation of the cartridges can cause the printer to indicate a carriage jam error. Follow these steps to remove, and then reinsert the cartridges.
  1. Press the Power button to turn the printer on, if it is not already on.
  2. Open the cartridge access door. The carriage moves to the cartridge access area. Wait until the carriage is idle and silent before continuing.
  3. To release the cartridge, lift the lid on the cartridge slot, and then gently push the lid back until it stops.
  4. Pull up on the cartridge to remove it from the slot.
      Figure : Remove the cartridge
      Image: Remove the cartridge
    1. Lift the lid
    2. Gently push the lid back
    3. Pull up on the cartridge
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or nozzle
    Image:  Do not touch the contacts or nozzle.
  5. Remove any protective tape that still might be on the nozzles.
    Figure : Remove any protective tape that still might be on the nozzles
    Image:  Remove any protective tape that still might be on the nozzles.
    Do not try to remove the copper-colored electrical strip.
  6. Hold the cartridge at a slight upward angle with the cartridge contacts facing the rear of the printer, and then slide the cartridge into the empty slot.
  7. Close the lid on the cartridge slot to secure the cartridge into place.
    Insert the color cartridge in the slot on the left. Insert the black cartridge in the slot on the right.
      Figure : Insert the cartridge
      Image: Insert the cartridge
    1. Insert the cartridge
    2. Close the lid
    3. The color cartridge is on the left, and the black cartridge is on the right
  8. Repeat the previous steps to remove, and then reinsert the other cartridge.
  9. Close the cartridge access door.
Solution three: Plug the printer directly into a wall outlet
Follow these steps to plug the printer directly into a wall outlet, and then print a test page.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from any power strips or surge suppressors.
  3. Plug the power cord directly into an electrical outlet.
  4. Reconnect the power cord to the rear of the printer.
  5. Turn on the printer.
Solution four: Service the printer
Contacting HP for service in Asia Pacific.
If you completed all the preceding steps and your product still has an issue, you might need further assistance from HP. Go to Contact HP Support to review available service options.
Country: Flag Thailand
