    Fix Windows 10 Update Issues
HP V195 19.45-inch LED Backlit Monitor - Specifications
Physical specifications
Feature
Display type
TFT LCD
Bezel color
Jack black
Panel specifications
Feature
Display size
49.53 cm (19.5 in)
Contrast ratio
700:1
Brightness
200 nits
Tilt
-4 + 1 to 18 + 1
Viewing angle (H/V)
CR(10):90/50
Color
Color gamut 72%
Response time
5 ms
Audio bar compatible
No
Kensington lock
Yes
USB (upstream/downstream)
No
ID thickness
47.5 mm
Texture/gloss
Texture
