    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP Deskjet 3540, ENVY 4500 Printers - First Time Printer Setup
This document is for the following printers:
HP Deskjet Ink Advantage 3545 e-All-in-One Printer
HP ENVY 4501 e-All-in-One Printer
HP ENVY 4505 e-All-in-One Printer
HP Deskjet Ink Advantage 3546 e-All-in-One Printer
HP ENVY 4502 e-All-in-One Printer
HP ENVY 4507 e-All-in-One Printer
HP Deskjet Ink Advantage 3548 e-All-in-One Printer
HP ENVY 4503 e-All-in-One Printer
HP ENVY 4508 e-All-in-One Printer
HP ENVY 4500 e-All-in-One Printer
HP ENVY 4504 e-All-in-One Printer
HP ENVY 4509 e-All-in-One Printer
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, and then install the ink cartridges. After your printer is set up, download and install the latest print driver.
If you are looking for the printer software, go to:
Remove the printer from the box and all tape, stickers, and packing materials from the printer.
  2. Remove all tape and packing materials from the outside of the printer.
  3. Raise the scanner lid, and then remove the packing tape.
    Figure : Removing the packing tape from under the scanner lid
    Image: Removing the packing tape from under the scanner lid
  4. Close the scanner lid.
  5. Gently grasp the handles on either side of the printer, raise the ink cartridge access door until it locks into place, and then remove all tape and packing material from inside the printer.
      Figure : Removing packing materials from inside the printer
      Image: Removing packing materials from inside the printer
    1. Opening the ink cartridge access door
    2. Removing the tape and packing material from the cleanout area
    3. Removing the tape and packing material from the ink cartridge access area
  6. Close the ink cartridge access door.
    Figure : Closing the ink cartridge access door
    Image: Closing the ink cartridge access door
  7. Open the paper tray door, pull it toward you to extend the paper tray, and then remove the packing tape.
    Figure : Opening the paper tray door and removing the packing tape
    Image: Opening  the paper tray door and removing the packing tape
  8. Push the paper tray forward until it clicks into place, and then close the paper tray door.
  9. Recycle the packing materials.
Step 2: Connect the power cord and set your preferences
Plug the printer into a power source, turn on the printer, and then set your preferences.
    Figure : Connecting the power cord
    Image: Connecting the power cord
  2. Turn on the printer.
  3. On the printer control panel, press the down arrow to select the language, and then press OK.
  4. Press the down arrow to select Yes, and then press OK.
    The Set Country/Region menu opens.
  5. Press the down arrow to select the country/region, and then press OK.
  6. Press the down arrow to select Yes, and then press OK.
Step 3: Load paper into the input tray
Load plain, white paper into the input tray after you set your preferences.
  1. Open the paper tray door, and then pull it toward you to extend the paper tray.
  2. Gently pull out the paper tray extender, and then lift up the paper catch.
    Figure : Pulling out the paper tray and the tray extender
    Image: Pulling out the  paper tray and  the  tray extender
  3. Slide the paper width guides to their outermost position.
    Figure : Sliding out the paper width guides
    Image: Sliding out the paper width guides
  4. Load a stack of plain, white paper into the paper tray with the short edge forward, and then push the stack into the tray until it stops.
    Figure : Loading the paper
    Image: Loading the paper
  5. Slide in the paper width guides until they rest against the edges of the paper.
    Figure : Sliding in the paper width guides
    Image: Sliding in the paper width guides
  6. Push the paper tray forward until it clicks into place.
    Figure : Pushing the paper tray forward until it clicks into place
    Image: Pushing the paper tray forward until  it clicks into place
Step 4: Install the ink cartridges
Install the HP ink cartridges that shipped in the box with the printer.
  1. Grasp the handles on either side of the ink cartridge access door, and then raise the door until it locks into place.
    The carriage moves to the access area.
    Figure : Opening the ink cartridge access door
    Image: Opening the ink cartridge access door
  2. Wait until the carriage is idle and silent before you continue.
  3. Remove one of the ink cartridges from its package. Be careful to only touch the black plastic on the ink cartridge.
    Figure : Removing the ink cartridge from its package
    Image: Removing the ink cartridge from its package
  4. Remove the plastic tape from the ink cartridge.
    Figure : Removing the plastic tape
    Image: Removing the plastic tape
  5. Lift up the lid on the ink cartridge slot.
    Figure : Lifting up the lid on the ink cartridge slot
    Image: Lifting up the lid on the ink cartridge slot
  6. Hold the ink cartridge by its sides with the nozzles toward the printer, and then press the ink cartridge forward into the slot until it snaps into place.
    Figure : Inserting the ink cartridge
    Image: Inserting the ink cartridge
  7. Close the lid on the ink cartridge slot to secure the ink cartridge into place.
    Figure : Closing the lid on the ink cartridge slot
    Image: Closing the lid on the ink cartridge slot
  8. Repeat the previous steps to install the other ink cartridge.
      Figure : Inserting the ink cartridges
      Image: Inserting the ink cartridges
    1. Inserting the ink cartridge
    2. Closing the lid
    3. The color ink cartridge is on the left, and the black ink cartridge is on the right
  9. Close the ink cartridge access door.
  10. Follow the instructions on the control panel to start the ink cartridge alignment.
    The printer prints an alignment page.
Step 5: Align the ink cartridges
Aligning the ink cartridges is necessary to achieve the best print quality.
  1. After the alignment page prints, place the page with the print side down on the scanner glass. Position it according to the engraved guides around the glass.
    Figure : Placing the alignment page on the scanner glass
    Image: Placing the alignment page on the scanner glass
  2. Close the scanner lid, and then touch OK.
    The printer aligns the ink cartridges.
You can download the latest version of the printing software from the following HP websites:
