for HP Deskjet 1010 printers - Setting Up the Printer Hardware
This document explains how to set up your printer hardware HP Deskjet 1010 and HP HP Deskjet Ink Advantage 1010 printers.
Do not connect the USB cable until instructed to do so.
Step 1: Unpack the printer
  1. Remove the tape and packing material from the outside of the printer.
  2. Open the output tray, and then open the cartridge access door.
    Figure : Open the output tray and cartridge access door
    Image: Open the output tray and cartridge access door
  3. Remove the tape and cardboard from inside the printer
    Figure : Remove the packing materials from inside the printer
    Image: Remove the packing materials from inside the printer.
  4. Close the cartridge access door.
    Figure : Close the cartridge access door
    Image: Close the cartridge access door.
Step 2: Check the contents of the box
Step 3: Connect the power cord and adapter
  1. Connect the adapter cord to the rear of the printer.
  2. Connect the power cord to the power adapter, and then plug the power cord into an electrical outlet.
      Figure : Connect the power cord
      Image: Connect the power cord.
    1. Connect the cord from the adapter to the rear of the printer
    2. Connect the power cord to the adapter
    3. Plug the power cord into the electrical outlet
Step 4: Turn on the power
Press the Power button to turn on the printer.
Figure : Turn on the printer
Image: Turn on the printer.
Step 5: Install the cartridges
  1. Lower the output tray, and then open the cartridge access door. The carriage moves to the center of the printer. Wait until the carriage is idle and silent before you continue.
    Figure : Open the output tray and the cartridge access door
  2. Remove the new cartridge from its package, and then carefully pull on the orange tab to remove the protective plastic tape.
    Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.
    Figure : Remove the protective tape
    Image: Remove the protective tape
  3. Hold the cartridge by its sides with the nozzles toward the printer, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
    • The tri-color cartridge () goes in the slot on the left
    • The black cartridge () goes in the slot on the right
    Figure : Insert the cartridge into its slot
    Image: Inserting the cartridge
  4. Push the cartridge forward into its slot until it snaps into place.
    Figure : Push the cartridge forward
    Image: Push the cartridge forward
  5. Repeat these steps to install the other cartridge.
    Figure : Install the second cartridge
    Image: install the other cartridge
  6. Close the cartridge access door.
Step 6: Load plain paper
Follow these steps to load plain paper into the printer.
  1. Lift the paper tray.
    Figure : Lift the paper tray
    Image: Lift the paper tray
  2. Lower the output tray, and then pull out the output tray extender.
    Figure : Pull out the tray extender
    Image: Pull out the output tray extender
  3. Slide the paper width guide to its outermost position.
  4. Load clean, white paper in the input tray with the short edge forward and the print side up.
    Figure : Load the paper
    Image: Load the paper
  5. Slide the paper width guide to the right until it stops at the edge of the paper but does not bend the paper.
    Figure : Slide the paper width guide against the paper
    Image: Slide the paper width guide against the paper
Step 7: Align the cartridges
After you install the cartridges, follow the steps for your operating system to align the cartridges. If you do not align the cartridges now, the printer prompts you to do so the next time you try to print.
