HP Printers - Mobile Printing Solutions Compatible with HP Printers
This document is for HP printers.
Find available options for your HP printer model to print from a smartphone, tablet, or Chromebook. Most printer models support several options, including the HP Smart app, ePrint cloud printing, and Wi-Fi Direct.
Mobile printing solutions for HP printers
Find your printer model for a list of options to print from your mobile device.
Learn more about the mobile printing solutions that work with your HP printer.
HP Smart app
Print and scan photos and documents, monitor ink levels, and troubleshoot printer issues with the HP Smart app on your Android and Apple iOS mobile devices.
HP Smart app logo
1 For supported printers, use the HP Smart app to connect printers to your wireless network.
  • Print to any network-connected HP printer that is on the same local wireless network as your mobile device.
  • Scan documents and images from your printer or mobile device camera, and share via email, save to cloud-based storage, or store on your mobile device.
The HP Smart app is compatible with Android OS 7.0 (Nougat) and later, Apple iOS 11 and later, or Apple iPadOS.
Print Anywhere
Print Anywhere allows you to see your printer status and send print jobs from the HP Smart app when you are away from your printer, using mobile data or another wireless network.
Print Anywhere is supported on select printers by HP Smart 6.0 on Android OS 5.0 and later or Apple iOS 10 and later devices.
Go to Print Anywhere with the HP Smart App for more information.
HP ePrint
HP ePrint is a secure cloud-based service that lets you print from anywhere with an active Internet connection. Email the document or photo you want to print directly to the printer.
HP ePrint logo
HP ePrint logo
HP ePrint is compatible with any mobile device with email sharing and an Internet connection.
Go to Setting Up and Using HP ePrint for more information.
HP Print for Chrome
Print from your Chromebook, Chrome device, or any Chrome browser to HP printers connected on the same network. Printing does not require your printer to be Google Cloud Print-enabled.
HP Print for Chrome logo
HP Print for Chrome is compatible with Chrome browser v44 and later installed on a Chromebook, or Windows, Mac, or Linux computer.
Go to Printing with the HP Print for Chrome App for more information.
HP Print Service Plugin (Android)
Install the HP Print Service Plugin to enable printing from your Android device to your HP printer over a wireless network.
HP Print Service Plugin (Android) logo
The HP Print Service Plugin is compatible with Android OS 5.0 and later.
HP Voice-Activated Printing
HP Voice-Activated Printing makes printing as easy as talking, using Alexa or Google Home. Use your voice to print a wide variety of everyday and creative documents, including games, coloring pages, to-do lists, comics, notebook paper, forms, and more. Content varies by voice assistant.
HP wireless direct
Print your photos or documents by establishing a direct wireless connection between your printer and your mobile device without a router.
HP Wireless Direct logo
HP wireless direct is compatible with most HP wireless printers released between late 2011 and mid-2014. To connect directly with HP printers released after mid-2014, go to Wi-Fi Direct.
Go to Printing with HP Wireless Direct for more information.
HP ePrint app (Android)
The HP ePrint app for Android is retired as of August 13, 2018.
HP ePrint app (Android only) logo
Go to HP ePrint App Retired (Android) for more information.
Amazon Fire devices
Print from your Amazon Fire device using the Mopria Print Service, a mobile printing standard supported by Amazon Fire devices and many HP printers.
Go to Printing from Amazon Fire Devices for more information.
Apple AirPrint
Print from most apps installed on an iPhone, iPad, or iPod touch. Select the Print option from the action icon to print to a printer connected to the same wireless network.
Apple AirPrint logo
Go to Printing with Apple AirPrint (iOS) for more information.
On iOS and macOS, most HP printers work with Apple AirPrint to provide full-quality printing without the need to download or install drivers. For additional functionality, please download the HP Smart app from the App Store for iPhone and iPad or the Mac App Store.
This mobile printing industry standard is supported by many HP printers. When you activate the Mopria Print Service on your mobile device, you can print over a wireless network or through a direct wireless connection to the printer.
Mopria Print Service logo
Mopria Print Service is compatible with Android 5.0 and later, Amazon Fire 5.0 and later, and HP Slate tablet with Android 4.1 and later.
NFC Touch-to-Print
Near field communication (NFC) Touch-to-Print enables printing from your Android mobile device directly to your NFC-capable HP printer without joining a local network or connecting to the Internet. To use NFC Touch-to-Print, your mobile device must be near the printer.
NFC touch-to-print logo
NFC Touch-to-Print is compatible with Android 4.0 and later with the HP ePrint app, and HP ElitePad 900.
Go to Getting Started with Touch-to-Print for more information.
Samsung Print Service Plugin
Print photos, documents, webpages, and emails from your Android smartphone or tablet to your network-connected HP printer using the Samsung Print Service Plugin, a free app available in the Google Play Store.
Samsung Print Service Plugin logo
The Samsung Print Service Plugin is compatible with Samsung devices with Android 4.2 and later, or non-Samsung devices with Android 4.4 and later.
USB On-The-Go (OTG) printing
Print from your Android device with a USB On-The-Go (OTG) cable connected to your HP printer.
Example of an Android device connected to the printer with a USB OTG cable
Go to Printing With a USB OTG Cable (Android) for more information.
Wi-Fi Direct
Wi-Fi Direct provides a direct wireless connection to your HP printer without joining a local network or connecting to the Internet. The technology is similar to Bluetooth, but uses Wi-Fi to work at greater distances and faster speeds.
Wi-Fi Direct logo
Wi-Fi Direct is compatible with most wireless HP printers released mid-2014 and later.
Go to Printing with Wi-Fi Direct for more information.
Windows 10 Mobile
Print from your Windows 10 Mobile device to your HP printer using the built-in printing solution.
Go to Printing with Windows 10 Mobile for more information.
Frequently asked questions
Review these frequently asked questions on mobile printing solutions that work with HP printers.
