HP Designjet T/Z Printer Series - 86:01 Error Can Occur from Incorrect Cutter Positioning
Environment
HP Designjet T1100 Printer series
HP Designjet T610 Printer series
HP Designjet Z2100 Photo Printer series
HP Designjet Z3100 Photo Printer series
HP Designjet Z3200 Photo Printer series
Questions/Symptoms
86:01 Error
Cause
If an user encounters an 86:01 error on a Z2100/Z3100/Z3200 or T1100/T610 printer it could be caused by the cutter being in the incorrect position on the cutter track (especially if the error occurs after a paper jam). This can also be common with new printers. Please refer to the following pictures for details.
Answer/Solution
The cutter is a user replaceable part. When troubleshooting the 86:01 error on the T and Z series, it is recommended to have the customer remove the cutter to verify whether or not this is the issue. The following pictures will show the correct and incorrect cutter placement. If the error does not occur during initialization with the cutter removed, ensure that the customer places the cutter back in the printer correctly and the issue should be resolved.
Some features of the tool may not be available at this time. We apologize for this inconvenience and are addressing the issue.Minimize Chat bot windowLoading ChatbotNew Message
