HP U160 15.6-inch LED Backlit Monitor - Overview
Product description
Product features
Feature
Models
C4M77AA, D4T56AA
Type
TN (Twisted Nematic) LED Backlit LCD
39.62 cm (15.6 in.) widescreen; diagonally measured
Active area (W x H)
34.42 x 19.35 cm (13.55 x 7.62 in)
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal/65° vertical (10:1 minimum contrast ratio)
Brightness (typical)
180 nits
Static contrast ratio (typical)
500:1
Dynamic contrast ratio (typical)
N/A
Response time (typical)
12 ms
Pixel pitch
0.252 mm
Backlight lamp life (to half brightness)
15,000 hours
Color gamut (typical)
60%
Color support
262,144 colors
Power supply
USB supplied power
Color
Black
Software overview
Feature
Featured software
Driver on included CD
Compatibility
Compatible with platforms using the VESA standard video modes. Recommended for use with HP products.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
