HP L2314 23-inch LED Backlit Monitor - Setting up the Monitor
Unpacking the Monitor
  1. Unpack the monitor. Make sure all contents are included. Store the packing box.
  2. Turn off the computer and other attached devices.
  3. Prepare a flat area to assemble the monitor. End-user may need a flat, soft, protected area for placing the monitor screen-down while preparing it for installation
Assembling the Monitor
Place the monitor in a convenient, well-ventilated location near the computer. Connect the monitor cables after the end-user has assembled the monitor.
The screen is fragile. Avoid touching or applying pressure to the LCD screen, doing so can cause damage.
For monitor displays with glossy bezels, consider the placement of the display, because the bezel might cause interfering reflections from surrounding light and bright surfaces.
  1. Set the monitor panel down on a flat, soft, protected table or desk surface.
  2. Slide the pedestal into the slot on the base until the pedestal clicks into the base.
    Figure : Assembling the Base and Pedestal
  3. Slide the hinge bracket on the monitor into the opening on top of the pedestal. The panel will click into place when fully inserted.
    Figure : Inserting the Monitor Panel
Connecting the monitor cables
Before connecting cables to the monitor, ensure that the computer and monitor are powered off.
When using a DVI, VGA, or HDMI signal, end-user must connect your audio output to external speakers.
The video source is determined by the video cable used. The monitor will automatically determine which inputs have valid video signals. The inputs can be selected by pressing the source button on the front panel.
Connecting the VGA Video Cable
Connect one end of the DVI-D video cable to the back of the monitor and the other end to the DVI-D video connector on the computer. End-user can use this cable only if the computer has a DVI compliant graphics card that is either integrated or installed. The DVI-D cable is included.
Figure : Connecting the VGA Cable (cable provided)
Connecting the DVI-D Video Cable
Figure : Connecting the DVI-D Video Cable
Connecting the HDMI Cable
Connect one end of the HDMI cable to the back of the monitor and the other end connector to the input device. The HDMI cable is not included.
The audio stream must be connected directly to external speakers or to an audio receiver.
Figure : Connecting the HDMI Cable (cable not provided)
Getting HDMI Sound
If end-user uses the HDMI to connect to a monitor model without speakers, end-user must activate HDMI sound by adjusting the setting in Microsoft Windows. If HDMI is not activated, end-user can not hear any sound. To activate HDMI sound on your computer:
  1. Right-click on the volume icon in the Windows system tray.
  2. Click Playback Devices. The sound window opens
  3. On the Playback tab, click the HDMI output audio device that is listed.
  4. Click Set Default.
  5. Click Apply.
  6. Click OK to close the window
Connecting the power cord
  1. Follow all electrical and power warnings
      warning:
    To reduce the risk of electric shock or damage to your equipment:
    • Do not disable the power-cord grounding plug. The grounding plug is an important safety feature. Plug the power cord into a grounded (earthed) electrical outlet.
    • Be sure that the grounded power outlet that the end-user plugs the power cord into is easily accessible to the operator and located as close to the equipment as possible. A power cord should be routed so that it is not likely to be walked on or pinched by items that are placed on it or against it.
    • Do not place anything on power cords or cables. Arrange them so that no one might accidentally step on or trip over them. Do not pull on a cord or cable.
  2. Connect the round end of the power supply cord to the monitor, and then connect one end of the power cord to the power supply and the other end to a grounded electrical outlet.
      warning:
    To prevent injury from electrical shock, the end-user should do one of the following if a properly grounded electrical outlet is not available:
    1. End-user should use an electrical outlet adapter that provides proper grounding.
    2. End-user should have a properly grounded electrical outlet installed.
    Figure : Connecting the Power Cord
Installing the Cable Management Clip
Install the cable management clip over the input cable and power cord to gather them together behind the monitor.
Figure : Installing the Cable management Clip
Adjusting The Tilt
For optimal viewing, adjust the screen tilt to your own preference, as follows:
To avoid breakage or other damage, avoid applying pressure to the LCD screen while changing the tilt.
  1. Face the front of the monitor and hold the base so that the end-user does not topple the monitor while changing the tilt.
  2. Adjust the tilt by moving the top edge of the monitor either toward or away, without touching the screen.
Figure : Tilt Adjustment
Country: Flag Thailand
