    We are upgrading our website
    If you experience errors during this time, please try again later. Sorry for the inconvenience.
    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP PCs - The HP Quick Start Application (Windows 8)
This document applies to HP computers with Windows 8 manufactured in 2013.
HP Quick Start is a Windows 8 software application that provides a familiar way to open apps from the Windows desktop.
In Windows 8, the Start button and Start menu from previous versions of Windows have been replaced with the Start screen. As an alternative to using the new Windows 8 Start screen, HP Quick Start organizes your apps in a format that resembles the traditional Windows Start menu.
This document guides you through using the HP Quick Start app.
Using HP Quick Start
The HP Quick Start application can be opened from the tile on the Start screen, or from the Windows desktop icon or taskbar icon. To open Quick Start, click the tile or the taskbar icon, or double-click the Desktop icon.
Figure : HP Quick Start tile
Image of the HP Quick Start tile on the Windows 8 Start screen
The HP Quick Start window opens in the bottom left corner of the Windows desktop. You can click and drag the Quick Start taskbar icon to move it to the leftmost position for familiarity, if desired.
Figure : Moving the HP Quick Start taskbar icon
Image of the HP Quick Start taskbar icon being moved to the leftmost position
Choose one of the following sections to learn more about using HP Quick Start:
