HP PCs - Device Manager Information (Windows 10, 8)
This document applies to HP and Compaq computers and tablets with Windows 10 or Windows 8.
This document contains information about using the Device Manager utility and information about Device Manager error codes.
Depending on your version of Windows, some graphics and information in this document might vary slightly.
You must be logged on as an administrator to change settings in Device Manager. Non-administrator user accounts can view settings, but not make changes.
Device Manager stores information about the devices installed in the computer, for example:
  • Installed hardware devices
  • Whether the device is working properly and gives error messages if it is not
  • IRQ ports
  • Memory allocations
  • Device driver
Device Manager allows you to change the driver properties used by the computer hardware.
Opening Device Manager to view error codes
To view error codes in Device Manager, follow these steps:
  1. In Windows, search for and open Device Manager.
  2. Select Device Manager in the menu.
    Figure : Device Manager
    Device Manager
  3. Double-click a device type (for example, double-click Display Adapters) to view the devices in that category.
  4. Right-click the desired device and click Properties.
    Figure : Display adapters
    Device Manager with display adapter selected
Understanding the Device Manager tabs
In Device Manager, click the arrow next to a device type, then right-click a specific device and select Properties. A properties window displays.
Some of the common tabs are shown below. The properties window for some devices might include other tabs not listed here, including:
  • Power Management
  • Volumes
  • Advanced
Details tab of Device Manager
When you click the Details tab, a Property selection and Value section are available.
Figure : Details tab
Details tab showing Property and Value information for the device
Events tab of Device Manager
The Events tab provides information and timestamps about events concerning the selected device.
Figure : Events tab
Events tab showing Event information and timestamps
  • The scroll box at the bottom contains a Conflicting device list. If a conflict is occurring, an error code is displayed on this list.
  • When Windows successfully detects a device, the Use automatic settings check box is selected. The device should function correctly.
  • If the resource settings for a device are based on Basic Configuration <n> (where <n> is any number from 0000 to 0009), it is possible to change the configuration by selecting a different Resource setting from the list.
  • If the settings for the device are not based on a Basic Configuration, click the Change Setting button and manually adjust the resource values. For example, to edit the Input/Output Range setting, use these steps:
    1. Click the Use automatic settings check box to clear it.
    2. Click the Change Setting button.
    3. Click the appropriate I/O range for the device.
    4. Save the new setting and click OK to exit.
    5. Restart the computer for the new settings to be recognized.
Using the toolbar buttons of Device Manager
Use the Device Manager toolbar to perform various actions to the devices you have on your system. See the table below for an explanation of the toolbar buttons.
Figure : Device Manager toolbar buttons
Graphics of the toolbar buttons
Symbol
Definition
Shows/hides console tree of Device Manager on the left side of window.
Displays the properties of the selected device.
Opens the Device Manager (Microsoft Management Console) Help files.
Displays the Device Manager Actions pane, which shows you possible actions to correct a device problem.
Scans for hardware changes.
Updates driver software for that device, if available.
Uninstalls this device from your system.
Disables this device on your system.
Rolling back a driver from Device Manager
If a device fails after updating the driver, roll back to the previously installed driver.
This video shows how to roll back a driver from Device Manager in Windows 10
  1. Open Device Manager.
  2. Double-click the device type. For example, double-click Display adapters to view the devices in that category.
  3. Right-click the device you want, then click Properties.
  4. Click the Driver tab.
  5. Click the Roll Back Driver button, and follow the directions on the screen.
    If the Roll Back Driver button is dimmed and cannot be selected, the driver has not been updated and cannot be rolled back.
    Figure : Rolling back the driver
Device Manager error symbols
Device Manager uses the following symbols to provide information about a particular error condition with a specific system device:
Symbol
Definition
Indicates the device is in a problem state. A device in a problem state can be functioning. A problem code explaining the problem is displayed for the device.
Indicates a disabled device. A disabled device is a device that is physically present in the system, consuming resources, but does not have a protected-mode driver loaded.
On a device resource in Computer properties, indicates that Use Automatic Settings is not selected for the device and that it was manually selected. It does not indicate a problem or a disabled device state.
This indicates that an exact (device-specific) driver is not available, and that a compatible driver has been installed.
Detailed error code information
In the table below, several errors can be resolved by updating the driver. For driver, BIOS patches, and software updates, browse to the HP Customer Support website and enter your product number to get a list of the available updates.
To remove a device from Device Manager, right-click the device name from the list, then click Uninstall.
You can also update a driver from the Driver tab of a device Properties page. Double-click the device name to get to the Properties page in Device Manager, click the Driver tab, then click the Update Driver button.
Refer to this table for a list of Device Manager error codes and suggested resolutions:
Error code
Error description
Suggested resolution
Code 1
Device is not configured properly
To resolve the problem, follow the instructions in the Device Status box.
In addition, you might be able to resolve this issue by removing the device in Device Manager, and adding the device through Control Panel.
Code 2
Depending on which device is failing, you might see one of two different messages. This code indicates that the device loader (DevLoader) did not load a device. When this device is a Root Bus DevLoader (for example, ISAPNP, PCI, or BIOS), the following message is displayed: Windows could not load the driver for this device because the computer is reporting two <type> bus types. (Code 2)
When the device is not root bus DevLoader, the following message is displayed: The <type> device loader(s) for this device could not load the device driver. (Code 2)
Try using the HP support document Updating the BIOS for desktop computers or Updating the BIOS for notebook computers.
Try removing the device from Device Manager and restart the computer to reinstall/reinitialize the device.
Code 3
The driver for this device might be corrupted, or your system might be running low on memory or other resources
Restarting the computer or deleting large files from the hard drive might also resolve this issue.
Code 4
INF file for this device is incorrect or the registry is corrupt. For example, the .inf file specifies a field that should be text, but is binary instead.
If you continue to receive this error code, update the driver.
Code 5
Device failure due to lack of an arbitrator.
To resolve this error code, update the driver as suggested.
If you continue to receive this error code, try removing the device from Device Manager and restartng the computer to reinstall/reinitialize the device.
Code 6
Conflict between this device and another device.
Click the Resources tab in the device properties to manually enter the settings or replace the device with one that is Plug and Play compatible.
Code 7
No configuration can be performed on the device.
If the device works correctly, you do not need to perform any steps to correct the code.
If the device does not work correctly, try removing the device from Device Manager and restarting the computer to reinstall/reinitialize the device.
If you continue to receive this error code, try updating the driver.
Code 8
Device loader (DevLoader) for a device could not be found. For example, the .inf file for the device might refer to a missing or invalid file.
For most cases, the resolution is to reinstall or update the driver.
As an alternative, try removing the device from Device Manager and restarting the computer to reinstall/reinitialize the device.
If you continue to receive this error code, contact the hardware manufacturer about updated drivers.
Code 8
If the device loader (DevLoader) is a system DevLoader, the following text is displayed: This device is not working properly because Windows cannot load the file <name> that loads the drivers for the device.
To fix this problem, perform a system recovery.
Code 9
Information in the registry for this device is invalid.
It might be possible to resolve this error by using Device Manager to remove the device, then reinstall the device.
If you continue to receive this error code, contact the hardware manufacturer for the proper registry settings.
Code 10
The device cannot start (for example, it is missing or is not working properly). This message can vary greatly because the text for this message can come from the driver.
To resolve this error code, make sure the device is attached to the computer correctly. For example, make sure all cables are connected firmly and that all adapter cards are inserted into their slots fully.
Follow the suggested solution button and update the device driver. It might be possible to remove the device and re-detect it automatically.
Error code
Error description
Code 11
Device failure.
Try updating the driver.
Try removing and reinstalling the device
Make sure the device is compatible with this version of Windows.
Code 12
This device cannot find enough free resources that it can use. If you want to use this device, you will need to disable one of the other devices on this system.
To resolve this error code, disable or remove one of the devices that is involved.
Click the Resources tab in the device properties to manually enter the settings, or replace the device with one that is Plug and Play compatible.
Code 13
Device failed due to a problem with the device driver.
Try removing the device from Device Manager and restarting the computer to reinstall/reinitialize the device.
Code 14
This device cannot work properly until you restart your computer.
Restart the computer.
Code 15
Device resources are conflicting with another device resources.
To resolve this error code, click the Resources tab in the device properties to manually enter the settings, or replace the device with one that is Plug and Play compatible.
Code 16
Windows cannot identify all the resources this device uses.
To resolve this error code, click the Resources tab in the device properties to manually enter the settings or replace the device with one that is Plug and Play compatible.
Update the driver, if available.
Code 17
Hardware is a multiple-function device and the .inf file for the device is providing invalid information on how to split the device resources to the child devices.
If you continue to receive this error code, please contact the hardware manufacturer about updated driver or installation files.
Code 18
Reinstall the drivers for this device.
To resolve this issue, follow the recommended solution.
If that does not work, try removing the device from Device Manager and restarting the computer to reinstall/reinitialize the device.
Code 19
Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged.
To fix this problem you can first try running a Troubleshooting Wizard.
If that does not work, you should uninstall, then reinstall the hardware device.
Next, try following the recommended solution, which will run Scanreg.exe.
If this does not resolve the issue, type scanreg/restore from a command prompt.
Code 20
VxD Loader (Vxdldr) returned an unknown result. For example, there could be a version mismatch between the device driver and the operating system.
If that does not work, try removing the device from Device Manager and install the device again.
Error Code
Error description
Code 21
Windows is removing this device.
Windows is in the process of uninstalling the driver for this device. Restart the computer.
If that does not work, try removing the device from Device Manager and restarting the computer again to reinstall/reinitialize the device.
Code 22
This device is disabled.
To resolve this error code, enable the device. To do so, right-click the device name in Device Manager, then select Enable, and restart the computer.
If this does not work, try removing the device from Device Manager and restart the computer to reinstall/reinitialize the device.
Is the device disabled in the BIOS? Try enabling the device using the HP support document BIOS Setup Utility Information and Menu Options.
Code 23
The device loader delayed the start of a device, then failed to inform Windows when it was ready to start the device.
To resolve this error code, verify the settings for the primary display adapter in Display properties.
Try removing the primary and secondary display adapters from Device Manager, then restarting the computer.
Verify that the drivers are current and installed correctly.
For devices other than display adapters, follow the recommended solution.
If that does not work, try removing the device from Device Manager and restarting the computer.
Code 24
Device is not present, is not working properly, or does not have all its drivers installed.
To resolve this error code, follow the recommended solutions.
If the device still does not work, make sure that the device is connected to your computer correctly. For example, make sure that all cables are correctly installed, or that the adapter cards are properly seated in their slots.
Code 25
This problem typically exists only during the first and second boots after Windows Setup copies all the files.
If this code is identified, it is likely an incomplete installation.
Performing a system recovery might be required.
Code 26
A device did not load correctly. There might be a problem in the device driver or not all the drivers were installed.
To resolve this error code, follow the recommended solution.
If this does not work, use Device Manager to remove the device, then restart the computer.
Code 27
The portion of the registry describing possible resources for a device does not contain valid entries. For example, the device is marked as configurable, but the configuration information in the .inf file is set to hardwired.
To resolve this error code, use Device Manager to remove the device, then restart the computer.
If the device still does not work, try updating the driver.
Code 28
The drivers for this device are not installed.
To resolve this issue, follow the recommended solution. If that does not work, try removing the device from Device Manager and restarting the computer.
You need to obtain drivers if the error continues to occur.
Code 29
This device is disabled because the firmware of the device did not give it the required resources.
Update the driver for the device.
If the error continues, the device might be incompatible with the version of Windows you are using, the device hardware might have failed, or the connection to the device might be bad.
Code 30
An IRQ cannot be shared.
There might be two hardware devices that are jumper set to the same IRQ. Update the hardware to Plug and Play compatible versions or correct the jumper settings.
Error code
Error description
Code 31
This device is not working properly because Windows cannot load the drivers required for this device.
Code 32
A driver (service) for this device has been disabled. An alternate driver might be providing this functionality.
The start type for this driver is set to disabled in the registry.
Code 33
Windows cannot determine which resources are required for this device.
Is the device compatible with the version of Windows you are using? You might need to replace the device with a Plug and Play compatible device.
Code 34
Windows cannot determine the settings for this device.
Consult the documentation that came with this device and use the Resource tab to set the configuration.
Code 35
Your computer's system firmware does not include enough information to properly configure and use this device.
To use this device, contact your computer manufacturer to obtain a firmware or BIOS update.
Code 36
This device is requesting a PCI interrupt but is configured for an ISA interrupt (or vice versa).
Please use the computer's system setup program to reconfigure the interrupt for this device.
Consult the documentation that came with the hardware and use the HP support document BIOS Setup Utility Information and Menu Options to change IRQ settings.
Code 37
Windows cannot initialize the device driver for this hardware.
Code 38
Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory.
Update the driver if the error continues.
Code 39
Windows cannot load the device driver for this hardware. The driver might be corrupted or missing.
Code 40
Windows cannot access this hardware because its service key information in the registry is missing or recorded incorrectly.
Perform a system recovery to recover the registry if the error persists.
Error code
Error description
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device.
Do the following:
  1. Remove the device name from Device Manager and shut down the computer.
  2. Remove the device from the computer, then reconnect it to make sure the connection is good.
  3. Turn on the computer.
If the error continues, make sure the device is compatible with the version of Windows being used.
Code 42
Windows cannot load the device driver for this hardware because there is a duplicate device already running in the system.
If the error persists, use the Troubleshooting tab to help correct this problem. If you have two devices of the same type and manufacturer, remove one of them from the computer.
Code 43
Windows has stopped this device because it has reported problems.
If the error persists, use the Troubleshooting tab to help correct this problem. Run HP Diagnostics to test for bad hardware.
Code 44
An application or service has shut down this hardware device.
Code 45
Currently, this hardware device is not connected to the computer.
This error code requires no action.
Code 46
Windows cannot gain access to this hardware device because the operating system is in the process of shutting down.
Code 47
Windows cannot use this hardware device because it has been prepared for safe removal, but it has not been removed from the computer.
Unplug the device from the computer, then plug it back in.
Restart the computer to reactivate the device.
Code 48
The software for this device has been blocked from starting because it is known to have problems with Windows.
Contact the hardware vendor for a new driver.
Update the driver or replace the device with compatible hardware.
Code 49
Windows cannot start new hardware devices because the system hive is too large (exceeds the Registry Size Limit).
Resolve this error by using the Device Manager to uninstall any unwanted or unused devices, then restart the computer.
You might need to perform a system recovery to restore the registry.
Code 52
Windows cannot verify the digital signature of the drivers for this device.
For more information about Device Manager error codes and troubleshooting steps, visit the Microsoft Error codes in Device Manager in Windows (in English) webpage.
