    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP PCs - Using Automated Troubleshooting (Windows 10, 8)
This document is for HP and Compaq computers with Windows 10 or 8.
Depending on your version of Windows, some graphics and information in this document might vary slightly.
This document describes how to use the automated troubleshooting tools in Windows. These tools use a combination of installed and online applications to detect and resolve many computer problems, such as problems with networking, system performance, and hardware devices.
For business computers, automated troubleshooting tools might not available. Contact your company's IT department or your local IT service to resolve issues.
Automated Troubleshooting tools
Use automated troubleshooting tools to detect and resolve many computer problems. Run the troubleshooting tool that matches the problem on your computer. Upon completion, a report generates that lists any messages and resolved problems it found. The Troubleshoot computer problems window contains four categories of troubleshooting tools.
  1. In Windows, search for and open Control Panel.
  2. In the Control Panel search field, type troubleshooting, and then click Troubleshooting in the search results.
    Troubleshooting search results in the Control Panel
  3. The Troubleshoot computer problems window opens. Review the following categories before you make a decision.
    Troubleshoot computer problems categories
Choose a troubleshooting tool from one of the four categories to resolve the problem. For example, to run a tool to check your Internet connection, select the Network and Internet category, and then select the Internet Connections tool.
The troubleshooting tool automatically diagnoses any problem it finds. Some problems are fixed as the tool runs. In other cases, the tool instructs you to take corrective action. When the tool finishes you can close it, or run the troubleshooter again to confirm the problem is fixed.
Selecting Internet Connections
Additional troubleshooting options
Windows provides additional features to manually select a troubleshooting tool, view troubleshooting history, and change maintenance settings. Use Remote Assistance to get help from a friend. Use the Steps Recorder to record the steps to recreate the problem, and then use the recording to get help from someone else.
  1. In Windows, search for and open the Control Panel.
    The Troubleshoot computer problems window opens and displays troubleshooting options on the left side pane.
    Options in left side pane of the Troubleshooting computer problems screen
  3. Choose from one of the troubleshooting options.
    • View all: Displays a list of all the installed troubleshooting tools. To run a Troubleshooting tool from this window, click the tool name.
      All installed troubleshooters
    • View history: Displays troubleshooting tools previously used and problems found.
      Troubleshooting history
    • Change settings: Opens System Maintenance. Turn on this tool to automatically perform routine maintenance, such as cleaning up temporary files and scanning for hard disk errors. It also alerts you to potential problems.
      Change troubleshooting settings
    • Get help from a friend: Opens Remote Assistance. Use Remote Assistance to connect two computers so that one person can provide troubleshooting help to the other person. You can also use Steps Recorder to automatically take screen snapshots as you reproduce the computer problem. Send these snapshots to someone else to help fix the problem. For more information go to How do I use Steps Recorder (in English).
      Remote Assistance tool screen
Troubleshooting tips
When you run the automated troubleshooting tool, it might display questions for you to answer or reset common settings as it works to detect and fix the problem. If the automated troubleshooting tool fixed the problem, you can close it. If it did not fix the problem, you can view several options that take you online to find an answer.
  3. Click any of the troubleshooting links under the main headings. For example, click Fix problems with Windows Update under System and Security.
    Selecting Fix problems with Windows Update in System and Security
  4. To manually apply repairs from a list of possible problems, click Advanced.
    Clicking Advanced
  5. Uncheck the Apply repairs automatically box, and then click Next.
    Unchecking Apply repairs automatically
  6. Select an option from the list of detected problems and possible solutions, and then follow the on-screen instructions.
    To re-enable Apply repairs automatically, check the Apply repairs automatically box.
