HP LaserJet Pro 500 color MFP M570 - Information about Tray 2
Tray capacity and paper orientation
To prevent jams, do not overfill trays. Be sure the top of the stack is below the tray-full indicator. For short/narrow and heavy/glossy paper, load paper to less than half of the tray-full indicators.
Tray 2 capacity
Paper type
Quantity
Paper
Range:
60 g/m2 to 220 g/m2
Equivalent to 250 sheets of 75 g/m2
Maximum stack height: 25 mm
For A5, A6, and 4x6 paper sizes, and for paper printed in a landscape orientation the maximum stack height is 15 mm,
Transparencies
Minimum: 0.102 mm thick
Glossy paper
Range:
105 g/m2 to 220 g/m2
100 sheets
Tray 2 paper orientation
Paper type
Image orientation
Duplex mode
How to load paper
Preprinted or letterhead
Portrait
1-sided printing
Face-up
Top edge at the right side of the tray
Figure : Paper orientation
2-sided printing
Face-down
Top edge at the left side of the tray
Landscape
1-sided printing
Face-up
Top edge toward the back of the product
2-sided printing
Face-down
Top edge toward the front of the product
Prepunched
Portrait or landscape
1- or 2-sided printing
Holes toward the back of the product
Load Tray 2
This tray holds up to 250 sheets of 75 g/m2 paper. If the paper is heavier, the tray does not hold as many sheets. Do not overfill the tray.
Do not print envelopes, labels, postcards, or unsupported sizes of paper from Tray 2. Print these types of paper only from Tray 1.
  1. Slide open the tray.
    Do not open the tray while it is in use.
    Figure : Open the tray
  2. Adjust the paper-length and paper-width guides by squeezing the adjustment latch and sliding the guides to the size of the paper being used.
    Figure : Adjust the paper guides
  3. Load paper into the tray face-up. Check the paper to verify the guides lightly touch the stack, but do not bend it.
    To prevent jams, do not overfill the tray. Be sure the top of the stack is below the tray full indicator.
    Figure : Load paper in the tray
    If the tray is not adjusted correctly, an error message might display during printing or the paper might jam.
  4. Slide the tray into the product.
    Figure : Close the tray
