    Looking for Site Help?
HP LaserJet Enterprise 700 color MFP M775 - Product comparison
Product comparison
M775dn
CC522A
M775f
CC523A
M775z
CC524A
M775z+
CF304A
Paper handling
Tray 1 (100-sheet capacity)
Tray 2 (250-sheet capacity)
Optional 500-sheet tray
Optional 500-sheet tray with cabinet
Optional 3x500-sheet tray
Optional 3,500-sheet high-capacity tray
Standard output bin (500-sheet capacity)
Stacker output bin (500-sheet capacity)
Automatic duplex printing
In-line 30-page stapler
Connectivity
Hi-Speed USB 2.0
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Easy-access USB port, for printing and scanning without a computer, and for upgrading the firmware
Storage
320 GB HP High-Performance Secure Hard Disk
Control-panel display
Touchscreen control panel
Print
Prints 30 pages per minute (ppm) on A4-size paper and 30 ppm on Letter-size paper
Easy-access USB printing (no computer required)
Fax
HP LaserJet Analog Fax Accessory 500
Copy and Scan
Copies and scans 30 pages ppm on A4-size paper and 30 ppm on Letter-size paper
Resolution is 600 x 300 pixels per inch (ppi)
100-page document feeder with automatic duplex copying and scanning
Easy-access USB copying and scanning (no computer required)
Color or monochrome scanning
Digital Send
Send to E-mail and Save to Network Folder
Supported operating systems1
Windows XP SP2 or later, 32-bit
Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best-effort support for the discontinued XP operating system.
Windows XP SP2 or later, 64-bit (print driver only, not supported by the software installer)
Windows Vista, 32-bit and 64-bit
Windows Vista Starter is not supported by the software installer or the print driver.
Windows 7, 32-bit and 64-bit
Windows 8, 32-bit and 64-bit
Windows 2003 Server SP1 or later, 32-bit and 64-bit
The software installer does not support the 64-bit version, but the print driver supports it.
Windows Server 2008, 32-bit and 64-bit
Windows Server 2008 R2, 64-bit
Max OS X 10.6 and 10.7
1The list of supported operating systems applies to the Windows PCL 6, PCL 5, PS, and Mac print drivers and to the in-box software installation CD. For a current list of supported operating systems, go to www.hp.com/go/lj700colorMFPM775_software.
Country: Flag Thailand
