    Fix Windows 10 Update Issues
Compaq R191 LED Backlit LCD Monitor - Product Specifications
The Compaq R191 is a 47 cm (18.5 inch) LED Backlit LCD Monitor
Figure : Photo of the Compaq R191 LED Backlit LCD monitor
Product numbers
B4G25AA
Features
The R191 LED Backlit Monitor has the following features:
  • VGA video input connector
  • Anti-Glare
  • Plug and Play capability (if supported by your computer system)
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Security lock
Technical specifications
LED feature
Specification
Display size
47 cm (18.5 inch) diagonal
Panel active area (width x height): 40.9 cm x 23 cm (16.1 inches x 9 inches)
Display type
Twisted Nematic (TN) with LED backlight
Aspect ratio
16:9
Brightness
200 nits
Input terminal
1 VGA connector
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 50-76 Hz
Viewing angle (typical)
Horizontal: 90 degrees
Vertical: 65 degrees
Recommended resolution (H x V)
1366 x 768 @ 60 Hz (same as max resolution)
Static contrast ratio
Up to 600:1
Response time (typical)
5 ms
Pixel pitch
0.3 mm
Pixels per inch
84.7
Color gamut
72% of NTSC
Power source
Internal power supply
Power consumption: 22 Watts max power consumption (20 Watts typical power consumption) , 0.5 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% through 80% Relative Humidity (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 80% to 95%
Dimensions (unpacked)
H x W x D:
36.2 x 44.9 x 19 cm (14.3 x 17.7 x 7.5 inches)
Weight (unpacked)
2.7 kg (6 lbs)
