HP EliteBook 8770w Mobile Workstation Specifications
Product description
HP EliteBook 8770w Mobile Workstation is designed to meet the military standard Mil-Std-810G for drop, vibration, dust, altitude, and high temperature operation with Intel Core i7 with vPro and Core i5 with vPro technology (optional).
Product features
Feature
Processor
  • 3rd Generation Intel Core i7-3920XM (2.9-GHz, 8MB L3 cache, 4 cores)
    Up to 3.80 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3820QM (2.7-GHz, 8MB L3 cache, 4 cores)
    Up to 3.70 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3720QM (2.6-GHz, 6MB L3 cache, 4 cores)
    Up to 3.60 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3610QM (2.3-GHz, 6MB L3 cache, 4 cores) (no vPro support)
    Up to 3.30 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i7-3520M (2.9-GHz, 4MB L3 cache, 2 cores)
  • 3rd Generation Intel Core i5-3360M (2.8-GHz, 3MB L3 cache, 2 cores)
    Up to 3.50 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3320M (2.6-GHz, 3MB L3 cache, 2 cores)
Mobile Intel QM77 Express
Graphics
  • AMD FirePro M4000 with 1GB dedicated GDDR5 video memory
    Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.1/4.1+ capable
  • AMD Eyefinity Technology supports up to five independent displays
    when using an HP Advanced Docking station
  • NVIDIA Quadro K3000M with 2GB dedicated GDDR5 video memory
    Microsoft DirectX 11 (Shader Model 5.0) and OpenGL 4.2 capable
  • NVIDIA Quadro K4000M with 4GB dedicated GDDR5 video memory
  • NVIDIA Quadro K5000M with 4GB dedicated GDDR5 video memory
Internal:
  • 17.3 in diagonal LED-backlit HD+ WVA anti-glare (1600 x 900)
  • 17.3 in diagonal LED-backlit FHD WVA anti-glare (1920 x 1080)
  • 17.3 in diagonal LED-backlit FHD UWVA anti-glare DreamColor (1920 x 1080)
  • HP Privacy Filter support
External:
Up to 32-bit per pixel color depth
DisplayPort:
Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
VGA:
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
DVI-D (single link):
Video signal available through DVI port in optional HP Docking Station (sold separately) supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Flash cache module
Optional 24GB mSATA Flash cache module support for Intel Smart Response Technology. (Available only with standard non-SED hard drive. )
Storage and drives
Hard drives:
  • 320/500/750GB 7200 rpm SMART SATA II
  • 500GB 7200 rpm SMART SATA II self encrypting drive
  • HP 3D driveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive (SSD):
  • 128/180GB SATA 6 Gb/s
  • 256GB SATA 6 Gb/s self encrypting drive
Optical drive
Fixed 12.7 mm SATA optical drive:
  • Blu-ray R/RE DVD+/-RW SuperMulti DL drive
  • Blu-ray ROM DVD+/-RW SuperMulti DL drive
  • DVD+/-RW SuperMulti DL
  • drive DVD-ROM drive
Second/Third hard drive:
  • 500GB 7200 rpm SMART SATA II hard drive
  • RAID 0, 1, 5 supported
Memory
Standard:
  • DDR3 PC3-12800 SDRAM (1600 MHz)
  • Two SODIMM slots (Dual-core processor) or four SODIMM slots (Quad-core processor) supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Maximum:
  • Upgradeable to 16384MB with optional 8192MB SODIMMs in both slots (Dual-core processor)
  • Upgradeable to 32768MB with optional 8192MB SODIMMs in all 4 slots (Quad-core processor)
Dual-channel:
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking/Communications
Wireless:
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Broadband Wireless (WWAN):
  • HP hs2350 HSPA+ Mobile broadband module
  • HP un2430 EV-DO/HSPA Mobile broadband module
Integrated wireless LAN options:
  • Intel Centrino Ultimate-N 6300 (3x3)
  • Intel Centrino Advanced-N 6205 (2x2)
  • Broadcom 43224AGN 802.11a/b/g/n (2x2) WiFi adapter
  • HP Integrated Module with Bluetooth 4.0+EDR Wireless technology
Communications:
  • Integrated Intel 82579LM Gigabit Network Connection (vPro configurations)
  • 56K V.92 modem
Audio
  • SRS Premium Sound PRO (Windows OS only)
  • Integrated stereo speakers
  • Integrated microphone (dual-microphone array when equipped with optional webcam)
  • Button for volume mute; function keys for volume up and down
  • Stereo headphone/line out
  • Stereo microphone/line in
Optional 720p HD webcam
  • HD format (widescreen)
  • Supports videoconferencing and still image capture
  • High quality fixed focus lens
  • Video capture at various resolutions up to 1280 x 720 resolution (720p) and up to 30 fps
  • M-JPEG compression supports higher frame rates for video capture and videoconferencing
  • Improved low light sensitivity
  • Improved dynamic range
Power
Power supply:
  • External HP 200 W Slim Smart AC adapter (172 x 96 x 25.4 mm)
  • External HP 230W Slim Smart AC adapter (200 x 100 x 25.4 mm)
    Power cord included is 1.8 m (6 ft). Total length including external AC adapter is 3.66 m (12 ft).
  • HP Fast Charge
Primary battery:
  • HP 8-cell Lithium-Ion Battery (83 WHr)
  • HP Long Life 8-cell Lithium-Ion Battery (75 WHr)
Secondary battery
  • HP BB09 Ultra Extended Life Notebook Battery (9-cell/100 WHr)
  • HP ST09 Extended Life Notebook Battery (9-cell/73 WHr)
System standby time:
Up to 1 week
Power conservation:
  • AMD PowerPlay technology
  • NVIDIA PowerMizer technology
  • Hibernation
  • Standby
  • ACPI compliance
System specifications
Feature
Stand-alone power requirements (AC power)
Nominal operating voltage
19.5 V
Average operating power
45 W
Maximum operating power
<200 W or <230 W
Temperature
Operating
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Display specifications
17.3-inch LED HD+ WVA anti-glare
Dimensions (W x H)
38.2 x 21.5 cm (15.0 x 8.5 in)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
300 nit typical
Pixel resolution
  • Pitch - 0.23868 x 0.23868 mm
  • Format - 1600 x 900
  • Configuration - RGB Stripe
Backlight
LED
PPI
107
Viewing angle
±60° Horizontal, ±50° Vertical (minimum)
60/60/50/50 (Left/Right/Down/Up) (minimum)
17.3-inch FHD UWVA LED anti-glare Dreamcolor
Dimensions (W x H)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typ)
Pixel resolution
  • Pitch - 0.1989 x 0.1989 mm
  • Format - 1920 x 1080
Backlight
LED
PPI
127
Viewing angle
±160° Horizontal, ±160° Vertical (minimum)
80/80/80/80 (Left/Right/Down/Up) (min)
Technology type
30-bit In-Plane Switching (IPS)
Color depth
10-bits/color
Display colors
Over 1 billion colors (native mode)
Color gamut coverage
CIE1931 (x,y)
CIE 1976 (u',v')
NTSC
109%
129%
AdobeRGB
114%
127%
sRGB
154%
148%
17.3-inch FHD WVA LED anti-glare
Dimensions (W x H)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typ)
Pixel resolution
Backlight
LED
PPI
127
PPI
118 ppi
Viewing angle
±60° Horizontal, ± 50° Vertical (minimum) or
±70° Horizontal, ±60° Vertical (typical)
Storage and drive specifications
Internal storage
750GB 7200 rpm SATA hard drive
500GB 7200 rpm SATA hard drive
320GB 7200 rpm SATA hard drive
500GB 7200 rpm SMART SATA II Self Encrypting Drive
SATA 6 Gb/s 256GB, 2.5-inch SATA SED Solid State Drive (SSD)
SATA 6 Gb/s 180GB, 2.5-inch Solid State Drive (SSD)
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive (SSD)
Drive weight
101 g (0.22 lb)
115 g (0.25 lb)
115 g (0.25 lb)
115 g (0.25 lb)
73 g (0.16 lb)
78 g (.171 lb)
73 g (0.16 lb)
Capacity
750GB
500GB
320GB
500GB
256GB
180GB
128GB
Height
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
7 mm (0.276 in)
7 mm (0.276 in)
7 mm (0.276 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
63.5 mm (2.50 in)
70 mm (2.76 in)
70 mm (2.76 in)
70 mm (2.76 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
SATA 3 (6 Gb/s)
SATA Gen 3 (6 Gb/s)
SATA 3 (6 Gb/s)
Transfer rate - Synchronous (maximum)
300 MB/s (drive capability)
Maximum sequential write: Up to 460 MB/s
Maximum sequential write: 550 MB/s
Maximum sequential write: 415 MB/s
Seek time (typical reads, including settling)
  • Single track - 1.5 ms
  • Average - 11 ms
  • Maximum - 22 ms
  • Average - 11 ms
  • Maximum - 22 ms
  • Average - 11 ms
  • Maximum - 22 ms
  • Single track - 1 ms
  • Average - 12 ms
  • Maximum - 20 ms
Maximum sequential read: Up to 260 MB/s
Maximum sequential read: 520 MB/s
Maximum sequential read: 175 MB/s
Rotational speed
7200 rpm
7200 rpm
7200 rpm
7200 rpm
Logical blocks
1,465,149,168
976,773,168
625,142,448
976,773,168
500,118,192
351,651,888
250,069,680
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
0° to 70°C (32° to 158°F) [case temp]
Features
ATA security
ATA security
ATA security
ATA security
  • ATA Security
  • ATA-8, SATA 3.0
  • DIPM
  • TRIM
  • ATA Security
  • ATA-8, SATA 3.0
  • DIPM
  • TRIM
  • ATA Security
  • ATA-8, SATA 3.0
  • DIPM
  • TRIM
Optical drives
Feature
DVD-ROM Drive
Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
Access times
Random
  • <140 ms CD (typical)
  • <160 ms DVD (typical)
Random
Random
  • <190 ms CD-ROM (typical)
  • <180ms DVD-ROM (typical)
  • <230 ms BD-ROM (typical)
Random
  • <205 ms BD-ROM (typical)
Max data transfer rate
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R Dual Layer
  • 6X - DVD-R Dual Layer
  • 5X DVD-RAM
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 4X - DVD+R Dual Layer
  • 4X - DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
  • 24X CD-ROM
  • 8X DVD-ROM
  • 24X CD-R
  • 16X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD+R Dual Layer
  • 6X DVD-R Dual Layer
  • 5X DVD-RAM
  • 6X BD-ROM
  • 6X BD-R
  • 2X BD-RE
Transfer mode
UDMA Mode 5
UDMA Mode 5
UDMA Mode 5
UDMA Mode 5
Interface
Gen 1 SATA
Gen 1 SATA
Gen 1 SATA
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
Supported media (write)
None
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM, BD-R, BD-RE
Max media capacity (read)
8.5GB
8.5GB
50.0GB
50.0GB
Max media capacity (write)
8.5GB
8.5GB
50.0GB
Transport
Tray loading
Tray loading
Tray loading
Tray loading
Network/Communications specifications
Intel 82579LM Gigabit network connection
Feature
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-negotiation (Automatic speed selection)
  • Full duplex operation at all speeds, half duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x flow control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE (Energy Efficient Ethernet)
  • Jumbo frame 9K
  • Auto MDI/MDIX crossover cable detection
Power management
  • ACPI compliant - multiple power modes
  • Energy detect low power mode (green ethernet)
Performance features
  • TCP/IP/UDP Checksum offload (configurable)
  • Protocol offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving side scaling
  • MACSec offload (802.3ae)
  • Intel vPro
  • iSCSI boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up frame); Wake-on-LAN from off (Magic Packet only)
  • PXE 2.1 remote boot
  • Statistics gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for ethernet cable status
Interface1
PCI express 1.1 x 1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Intel 82579LM/82579V ethernet network connection
1. Intel 82579 PCIe interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5GT/S) speed.
V.92 56K data/Fax modem
Feature
Form factor
MDC 1.5 daughtercard
Power management support
APM revision 1.2, ACPI
Approvals/Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data mode capabilities
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (compression)
  • V.42 (LAPM, MNP2-4) (error correction)
Optional symbol rates
  • 2800, 3429
  • Asymmetric Symbol rates
Synchronous primary channel data signaling rates
  • 3600, 31200
  • Automatic rate re-negotiation
  • V.34
  • V.32bis
  • V.32
  • V.23
  • V.22bis
  • V.22
  • V.21
  • Bell 212A
  • Bell 103J
Fax mode capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
  • T.31
Command set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
Feature
HP un2430 EV-DO/HSPA mobile Broadband module
HP hs2350 HSPA+ mobile Broadband module
Technology/Operating bands
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz (DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • 1xEVDO/1xRTT with receive diversity: 850 MHz (Band Class0-Cell), 1900 MHz (Band Class1-PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 Mhz (UTRA FDD Band II), 900 Mhz (UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class A, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9
  • UMTS/WCDMA: Release 99 and Release 6
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
  • GSM/GPRS/EDGE: Class B, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced receiver Type 3i
Wireless parametric standards
Meets or exceeds TIA/EIA IS-98-D
Complies with 3GPP specifications
Maximum data rates
  • UMTS (HSPA) - 14.4 Mb/s (Download ), 5.76 Mb/s (Upload)
  • CDMA (EVDO Release A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
  • UMTS (HSPA) - 21 Mb/s (Download ), 5.76 Mb/s (Upload)
GPS
  • Standalone GPS enabled
  • gpsOneXTRATM
  • Standalone, A-GPS (Internet- and Network assisted)
GPS bands
L1 - 1575.42 MHz
1575.42 MHz (± 1.023 MHz)
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • CDMA: 24 dBm (+0.7/-2)
  • GSM/EDGE
  • GSM850 & GSM900 bands
    • GPRS: +33 dBm ± 2 dBm (class 4)
    • EGPRS: +27 dBm ± 3 dBm (class E2)
  • DCS1800 & PCS1900 bands
    • GPRS: +30 dBm ± 2 dBm (class 1)
    • EGPRS: +26 dBm +4/-3 dBm (class E2)
  • UMTS
  • UTRA FDD bands
    • +24 dBm +4 / -3 dBm (class 3)
Maximum power consumption
2750 mA (peak); 1100 mA (average)
2000 mA (peak); 600 mA (average)
Power consumption, idle not connected
20 mA
5 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
<12 g
Dimensions (Length x Width x Thickness)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, operating
3.3 V +/- 10%
3.3 V +/- 9%
Temperature, operating (from TIA/EIA/IS-98-D)
  • -30° to 70°C (-22° to 158°F) (full RF performance)
  • -30° to 75°C (-22° to 167°F) (reduced RF performance)
  • -10° to 65°C (14° to 149°F) (full RF performance)
  • -10° to 75°C (14° to 167°F) (reduced RF performance)
Temperature, non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
-30° to 85°C (-22° to 185°F)
Humidity, non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP Connection Manager
LED activity
  • LED Off - Radio Off
  • Solid LED On - Radio On
Feature
Intel Centrino Advanced-N 6205 (2 x 2)
Broadcom 43224AGN 802.11a/b/g/n (2 x 2)
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows 7, Windows Vista and XP
  • Wi-Fi certified
  • Wi-Fi certified
Frequency band
2.4 GHz and 5 GHz
2.4 GHz and 5 GHz
2.4 GHz and 5 GHz
Antenna structure
  • 3 transmit
  • 3 receive (3 x 3)
  • 2 transmit
  • 2 receive (2 x 2)
NA
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: Many possible data rates, ranging from 6 Mb/s to 450 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
  • 802.11n: 66 possible data rates, ranging from 6 Mb/s to 300 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
  • 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 6, 6.5, 9, 12, 13, 13.5, 18, 19.5, 24, 26, 27, 36, 39, 40.5, 48, 52, 54, 58.5, 65, 78, 81, 104, 108, 117, 121.5, 130, 135, 162, 216, 243, 270, 300 Mb/s
Frequency support
NA
NA
  • 20 MHz: 2.4 GHz and 5 GHz bands
  • 40 MHz: 2.4 GHz and 5 GHz bands
Modulation
  • Direct Sequence Spread Spectrum
  • Db/sK, DQPSK, CCK, OFDM, b/sK, QPSK, 16-QAM, 64-QAM
  • b/sK, QPSK, 16QAM, 64QAM, 256QAM, Db/sK,DQPSK and CCK
Security1
  • Authentication: WPA and WPA2, 802.1x (EAP_TLS, TTLS, PEAP, LEAP, EAP-FAST)
  • Authentication protocols: PAP, CHAP, TLS, GTC, MS-CHAP, MS-CHAPv2
  • Encryption: 64 and 128-bit WEP, AES-CCMP, CKIP, TKIP
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
  • Supports 64 and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST
  • Support for Cisco Security features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access point required)
Roaming
IEEE 802.11 compliant roaming between access points
IEEE 802.11 compliant roaming between 2.4 GHz band access points
Output power (for CCK and OFDM)2
17 dBm typical
17 dBm max
  • 17 dBm, nominal
  • 15 dBm, nominal (for OFDM; power varies by data rate)
Power consumption
  • Transmit: 1.4 W (average, with one spatial streams)
  • Receive: 1.3 W (average with two receive chains)
  • Idle mode3: 30 mW (average)
  • Radio off: 20 mW (max)
  • Transmit: 2.3 W (max, with two spatial streams)
  • Receive: 1 W (max with two spatial streams)
  • Idle mode3: 35 mW (average)
  • Idle associated: 250 mW
  • Idle unassociated: 150 mW
  • Transmit/Receive 20 MHz channel: 2.0 W (max)
  • Transmit/Receive 40 MHz channel: 2.0 W (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity4
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
  • 270 Mb/s: -68 dBm
  • 54 Mb/s: -75 dBm
  • 11 Mb/s: -88 dBm
  • 1 Mb/s: -96 dBm
Antenna connections
3 U.FL type connectors, 50 ohm nominal impedance
2 U.FL type connectors, 50 ohm nominal impedance
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure.
Form factor
PCI-Express Half-MiniCard
3.4 g (0.0075 lb)
3.4 g (0.0075 lb)
6 g (0.013 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
4.75 x 26.65 x 30 mm (0.19 x 1.05 x 1.18 in)
Operating voltage
3.3 V +/- 9%
3.3 V +/- 9%
3.3 V +/- 10%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
  • Operating: -10° to 65°C (14° to 149°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
  • Non-operating: 5% to 95% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
  • LED Off - Radio OFF
  • Solid LED On - Radio ON
1. Check latest software/driver release for updates on supported security features.
2. Maximum output power may vary by country according to local regulations.
3. In Power Save Polling mode and on battery power.
4. Receiver sensitivity is measured at a packet error rate of 8% for 802.11b (CCK modulation) and a packet error rate of 10% for 802.11a/g (OFDM modulation).
5. WLAN supplier's client utility is required for Cisco Compatible Extensions support with Microsoft Windows XP. WLAN may also be compatible with certain third-party software supplicants. WLAN supplier IHV extensions required for Cisco Compatible Extensions support for Microsoft Windows Vista.
HP integrated module with Bluetooth 4.0+EDR wireless technology
Feature
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate
  • Throughput: up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3, 64 kb/s
  • Voice channels Asynchronous Connection Less links 2178.1/177.1 kb/s asymmetric or 1306.9 kb/s symmetric
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
  • Peak (Tx) 264 mW
  • Peak (Rx) 231 mW
  • Sleep <1 mW
Antenna
Internally integrated within module
Range
Up 10 m (33 ft )
Electrical interface
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Bluetooth software
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
Link topology
  • Point to Point
  • Multipoint Pico Nets up to 7 slaves
Security
Full support of Bluetooth Security Provisions
Power management
Microsoft Windows ACPI, and USB Bus Support Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniffx
Certifications
All necessary regulatory approvals for supported countries, including:
  • FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Temperature
  • Operating: -10° to 70°C (-14° to 158°F)
  • Non-operating: -40° to 212°C (-40° to 100°F)
Humidity
  • Operating: 0% to 90%
  • Non-operating: 50% to 95%
Altitude
  • Operating: 4,572 m (15,000 ft)
  • Non-operating: 12,192 m (40,000 ft)
Bluetooth profiles supported
  • Serial Port Profile (SPP)
    Service Discovery Application Profile (SDAP)
    Dial-Up Networking (DUN)
    Generic Object Exchange Profile (GOEP)
    Object Push Profile (OPP)
    File Transfer Profile (FTP)
    Synchronization Profile (SYNC)
    Hard Copy Cable Replacement (HCRP)
    Personal Area Networking Profile (PAN)
    Human Interface Device Profile (HID)
    FAX Profile (FAX)
    Basic Imaging Profile (BIP)
    Headset Profile (HSP)
    Hands Free Profile (HFP)
    Advanced Audio Distribution Profile (A2DP)
Security
HP fingerprint sensor
Feature
Mobile voltage operation
3.0 - 3.6 V single supply
0° - 70°C (32° - 158°F)
Current consumption @ 3.3 V
  • Less than 70 mA peak imaging and scrolling
  • Less than 25 mA hardware finger detection
  • Advanced Power Management
High-rate image capture
Up to 240 image frames/sec
ESD resistance
IEC 61000-4-2 Level 4 (±15 KV)
Detection matrix
  • 192 x 16 Pixels
  • 9.7 x 0.81 mm
  • 500 ppi High-Resolution Images
Audio specifications
Feature
Audio
Implementation: IDT 92HD80 High Definition CODEC
Function key volume controls: Volume up, volume down
Mute button: Volume mute button with LED indicator
Full duplex: Yes
Microphone in: Stereo
Headphone/Line out: Stereo
Integrated microphone: Yes, dual digital microphone array
Audio output quality
Frequency response: 20 Hz - 20 kHz
Signal to noise ratio: >85 dB
Total harmonic distortion: 0.01%
Noise floor: -110 dB
Play/Record sampling rate(s): 8 kHz - 48 kHz
DAC: 16, 20 or 24-bit
ADC: 16 or 20-bit
Internal stereo speaker
Power rating: 2 Watts
Impedance: 4 ohms
Power specifications
Power adapters
Feature
HP 230-W Slim Smart AC adapter
HP 200-W slim smart AC adapter
Dimensions
20.0 x 10.0 x 4.0 cm (7.87 x 3.94 x 1.57 in)
17.0 x 8.5 x 3.5 cm (6.69 x 3.35 x 1.38 in)
1300 g (2.87 lb)
920 g (2.03 lb)
Input
100 to 240 V ac
100 to 240 V ac
Input efficiency
87% min at 115 V ac
87% min at 115 V ac
Input frequency range
47 to 63 Hz
47 to 63 Hz
Input AC current
  • 3.5 A at 90 V ac
  • 1.75 A at 180 V ac
  • 2.9 A at 90 V ac
  • 1.45 A at 180 V ac
Output
230 W
200 W
DC output voltage
19.5 V
19.5 V
Hold-up time
5 ms at 115 V ac input
Output current limit
<18 A, Over voltage protection- 29 V max automatic shutdown
<16 A, Over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
0° to 40°C (32° to 104°F)
Non-operating (storage) temperature
-20° to 65°C (-4° to 149°F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
20% to 80%
Storage humidity
10% to 90%
10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
Battery
Feature
Optional HP BB09 Ultra Extended Life Notebook Battery (secondary battery)
Optional HP ST09 Extended Life Notebook Battery ("Travel Battery") (secondary battery)
Dimensions (H x W x L)
2 x 5.3 x 27 cm (0.8 x 2.1 x 10.6 in)
3 x 15 x 29 cm (1.2 x 5.9 x 11.4 in)
3 x 15.5 x 30.5 cm (1.2 x 6.1 x 12 in)
Weight (max)
0.442 kg (0.99lb)
0.442 kg (0.99lb)
.682kg (.1.5lb)
.550kg (1.2lb)
Cells/Type
Lithium-Ion
  • 8-cell
  • Lithium-Ion
Lithium-Ion
Lithium-Ion polymer
Voltage
14.8 V
14.4 V
11.25 V
11.1 V
Amp-hour capacity
5.6 Ah
5.1 Ah
8.85 Ah
6.6 Ah
Watt-hour capacity
83 Wh
75 Wh
100 Wh
73 Wh
Operating temperature (Charging)
0° to 45°C (32° to 113°F)
Operating temperature (Discharging)
-10° to 50°C (14° to 122°F)
-10° to 60°C (14° to 140°F)
Non-operating temperature
-20° to 50°C (-4° to 122°F)
Battery re-charge time
  • System in Off or Standby mode: 2.5 hours
  • System On: 3 to 5 hours
  • System in Off for Standby mode: 2.5 hours
  • System in Off or Standby mode: 3.5 to 5 hours
  • System On: 4 to 7 hours
Fuel gauge LED
No
No
No
Yes
1 year
3 year
1 year
1 year
Compatible with optional travel battery
Yes
Yes
No
Yes
Physical specifications
Feature
  • Starting at 3.47 kg (7.66 lb ) with SSD and weight saver (no optical drive)
  • Starting at 3.60 kg (7.96 lb) with hard drive and DVD-R/W drive
Dimensions (w x d x h)
37.4 (at front)/42.7 (at rear) x 416.5 x 272.7 mm (1.47 (at front)/1.68 (at rear) x 15.0 x 10.1 in)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6-cell battery, hard drive, 1GB memory, and no optical drive. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled:
  • Genuine Windows 7 Professional 32
  • Genuine Windows 7 Professional 64
  • Genuine Windows 7 Home Premium 64
  • FreeDOS
Supported:
  • Genuine Windows 7 Enterprise 32
  • Genuine Windows 7 Enterprise 64
  • Genuine Windows 7 Ultimate 32
  • Genuine Windows 7 Ultimate 64
  • Genuine Windows XP Professional 32
  • Genuine Windows XP Professional 64
  • SuSE Linux Enterprise Desktop 11
  • SP2 Red Hat Enterprise Linux 6.x
Certified:
  • Red Hat Enterprise Linux 6.x
Preinstalled software
  • HP Recovery Manager
  • HP Performance Advisor
  • HP Support Assistant
  • HP ProtectTools Security Manager
  • HP ProtectTools for Central Management
  • HP Hotkey Support HP Power Assistant
  • HP Connection Manager
  • HP GPS and Location (select models)
  • Adobe Flash Player
  • Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook. Buy Office 2010 to use the full-featured software.
  • Microsoft Security Essentials
  • PDF Complete Special Edition
  • Corel WinDVD SD (DVD) Player, or HD (Blu-ray) Player (select models)
  • Roxio Secure Burn (select models)
  • Roxio MyDVD Business 2010 (select models)
  • HP Webcam Software (select models)
  • WinZip Basic
Security software
Standard:
  • HP ProtectTools Security Manager (standard modules include):
    • Credential Manager
    • Computrace Pro
    • Device Access Manager
    • Drive Encryption
    • Face Recognition (webcam configurations only)
    • File Sanitizer
    • Privacy Manager
    • Embedded Security
  • HP Fingerprint Sensor
  • Integrated Smart Card Reader
  • Enhanced Pre-Boot Security (Multiuser/Multifactor)
  • HP Spare Key (requires initial user setup)
  • One-Step Logon
  • TPM 1.2 Embedded Security Chip
  • HP Disk Sanitizer
  • Security lock slot
  • Support for Intel AT
Optional:
  • HP Privacy Filter
  • Computrace Pro for HP ProtectTools with GPS Tracking
Environmental specifications
Feature
115 V ac
230 V ac
100 V ac
Energy consumption
Normal operation
15.4 W
14.6 W
14.8 W
Sleep (Energy Star low power mode)
0.98 W
1.03 W
0.98 W
Off
0.57 W
0.93 W
0.6 W
Heat dissipation1
Normal operation
53 BTU/hr
50 BTU/hr
51 BTU/hr
Sleep
3 BTU/hr
3 BTU/hr
3 BTU/hr
Off
2 BTU/hr
2 BTU/hr
2 BTU/hr
Declared noise emissions (in accordance with ISO 7779 and ISO 9296)
System fan off2
Sound Power (LWAd, bels)
Sound pressure (LpAm, decibels)
Idle
26
Fixed disk (random writes)
35
1. Heat dissipation is calculated based on the measured watts, assuming the service level is attained for one hour.
2. System fan is usually off except when charging the battery.
Safety certifications
Feature
Eco-label certifications
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
  • US Energy Star
  • IT ECO declaration
  • EPEAT Gold where HP registers commercial desktop products.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
