The HP s1935a is a 47 cm (18.5 inch) LCD monitor.
Figure : Photo of the HP s1935a LCD monitor
LED feature
Specification
Display size
47 cm (18.5 inch) diagonal
Panel active area (width x height):
40.9 cm x 23 cm (16.1 inches x 9.0 inches)
Display type
TN
Aspect ratio
16:9
Brightness
200 nits
Input terminal
1 DVI-D connector
1 VGA connector
Speaker output power
1.5 watt per channel
Scanning frequency
Horizontal scan range 30-83 KHz
Vertical scan range 55-75 Hz
Viewing angle
Horizontal viewing angle (typical): 90 degrees
Vertical viewing angle (typical): 50 degrees
Recommended resolution (H x V)
1366 x 768 @ 60 Hz (same as max resolution)
Static contrast ratio
Up to 600:1
Dynamic contrast ratio
Up to 5,000:1
Response time
5 ms (on/off)
Pixel pitch
0.300 mm
Pixels per inch
84.7
Color gamut
57% of NTSC
HDCP (High-bandwidth Digital Content Protection)
Yes (supported on DVI-D input)
Power source
Internal power supply
Power consumption: 37 Watts max power consumption (23 Watts typical power consumption) , 1 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 15% RH through 90% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 90% RH (non-condensing)
Dimensions
H x W x D (unpacked):
34.1 x 44 x 18 cm (13.4 x 17.3 x 7.1 inches)
Unpacked: 3.2 Kg (7.0 lbs)
