Compaq R191 19-inch Diagonal LCD Monitor - Overview
Product description
Product features
Feature
Part number
B4G25AA
Display panel type
TN w/ LED backlight
Native resolution
1366 x 768 @60 Hz
Aspect ratio
16:9
Brightness (typical)
200 nits
Static contrast ratio (typical)
600:1
Dynamic Contrast Ratio (DCR)
2M:1
Pixel pitch
0.3 mm (0.011 in)
Pixels Per Inch (PPI)
84.7
BrightView panel
No
Anti-Glare panel
Anti-Glare panel
Response time (typical)
5 ms
Color gamut
72% of NTSC
Horizontal viewing angle (typical CR>10)
90°
Vertical viewing angle (typical CR>10)
65°
Panel active area (w x h)
409.8 x 230.4 mm (16.13 x 9.07 in)
Preset graphic modes/Supported resolutions
  • 640 x 480 @60 Hz
  • 720 x 400 @60 Hz
  • 800 x 600 @60 Hz
  • 1024 x 768 @60 Hz
  • 1280 x 720 @60 Hz
  • 1280 x 1024 @60 Hz
  • 1366 x 768 @60 Hz
Maximum resolution
1366 x 768 @ 60 Hz
Recommended resolution
1366 x 768 @ 60 Hz
Vertical scan range
50 to 76 Hz
Horizontal scan range
24 to 83 kHz
Exterior color of monitor
Champagne gold + jack black
Plug n Play
Yes
Tilt (Include degrees of tilt)
-5° to +15° vertical
Input connector types
  • VGA - Yes
  • DVI - No
  • HDMI - No
  • HDCP - No
  • Audio - No
  • USB - No
  • Card reader - No
  • DisplayPort 1.1 - No
Links to product QuickSpecs
Direct links to the QuickSpecs will be added as soon as they become available.
