    Windows 11 Upgrade Guide
HP EliteBook 2570p Notebook PC Product Specifications
Product image
Product features
Feature
Mobile Intel QM77 Express (vPro support)
Graphics
Intel HD Graphics 4000
Processor1
  • 3rd Generation Intel Core i7-3520M (2.90 GHz, 4MB L3 cache, 35 W, 2 cores)
    Up to 3.60 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3360M (2.80 GHz, 3MB L3 cache, 35 W, 2 cores)
    Up to 3.50 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3320M (2.60 GHz, 3MB L3 cache, 35 W, 2 cores)
    Up to 3.30 GHz with Intel Turbo Boost Technology
  • 3rd Generation Intel Core i5-3210M (2.50 GHz, 3MB L3 cache, 35 W, 2 cores)
    Up to 3.10 GHz with Intel Turbo Boost Technology
Memory2
Standard
  • DDR3 PC3-12800 SDRAM (1600 MHz)
  • Two SODIMM slots supporting dual-channel memory
  • 2GB, 4GB, and 8GB SODIMMs
Maximum
Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
Dual-channel
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
HP 3D DriveGuard (Windows only)
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive
Solid State Drive
  • 2.5-inch SSD III
  • 128GB SATA III
  • 180GB SATA III
  • 240GB SATA III
  • 256GB SATA III Self Encrypting Drive
1: Multi-Core is designed to improve performance of certain software products. Not all customers or software applications will necessarily benefit from use of this technology. 64-bit computing on Intel architecture requires a computer system with a processor, chipset, BIOS, operating system, device drivers, and applications enabled for Intel 64 architecture. Processors will not operate (including 32-bit operation) without an Intel 64 architecture-enabled BIOS. Performance will vary depending on your hardware and software configurations. Intel's numbering is not a measurement of higher performance.
2: Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If you mix memory speeds, the system will perform at the lower memory speed. With Windows Starter 32-bit operating systems, the amount of usable memory is dependent upon your configuration, so that above 3GB all memory may not be available due to system resource requirements.
Electrical specifications
Specification
Power supply
  • External 65-W HP non-Smart AC adapter
  • Power cord included is 1.8 m (6 ft)
  • Total length including external AC adapter is 3.66 m (12 ft).
  • HP Fast Charge
Primary battery
  • HP 9-cell Lithium-Ion Battery (100 Whr)
  • HP 6-cell Lithium-Ion Battery (62 Whr)
  • HP 3-cell Lithium-Ion Battery (31 Whr)
Secondary battery
HP Long Life Battery (6-cell/55 Whr)
Battery life1
  • HP 9-cell primary battery: Up to 15 hours and 15 minutes
  •   HP 6-cell primary battery: Up to 9 hours and 15 minutes
System standby time
Up to 30 days
Stand-alone power requirements (AC power)
Nominal operating voltage
18.5 V
Max operating power
<65 W
1: Battery life will vary depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery will naturally decrease with time and usage. Click here to see MobileMark07 battery benchmark for additional details.
Displays
Specification
12.5-inch LED-backlit HD anti-glare
Dimensions (W x H)
27.7 x 15.6 cm (10.63 x 6.4 in)
Internal
12.5-inch diagonal LED-backlit HD 16:9 anti-glare (1366 x 768)
External
Up to 32-bit per pixel color depth
DisplayPort
Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
VGA
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
Diagonal size
31.75 cm (12.5 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (typical)
Refresh rate
60 Hz
Brightness
200 nit (typical)
Pixel resolution
  • Pitch: 0.2025 mm
  • Format: 1366 x 768
  • Configuration: RGB Stripe
Backlight
LED
PPI
125
Viewing angle
  • ±30° Horizontal, ±10° Vertical (minimum)
  • 30/30/20/10 (Left/Right/Down/Up) (minimum) or
  • 45/45/35/25 (Left/Right/Down/Up) (typical)
Storage and drives
Internal storage
Drive Weight
Capacity
Height
Width
Interface
Transfer Rate
Seek Time
Performance
Rotational Speed
Logical Blocks
Operating Temperature
Features
750GB 7200 rpm SATA hard drive
101 g (0.22 lb)
750GB
9.5 mm (0.37 in)
70 mm (2.75 in)
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Synchronous (maximum) 300 MB/s (drive capability)
  • Single track: 1.5 ms
  • Average: 11 ms
  • Maximum: 22 ms
7200 rpm
1,465,149,168
0° to 60°C (32° to 140°F) (case temp)
ATA security
500GB 7200 rpm SMART SATA II Self Encrypting Drive
115 g (0.25 lbs)
500GB
9.5 mm (0.37 in)
63.5 mm (2.50 in)
  • Single track: 1 ms
  • Average: 12 ms
  • Maximum: 20 ms
7200 rpm
976,773,168
ATA security
320GB 7200 rpm SATA Hard Drive
115 g (0.25 lbs)
320GB
9.5 mm (0.37 in)or on some models 7 mm (0.28 in)
70 mm (2.75 in)
  • Average: 11 ms
  • Maximum: 22 ms
7200 rpm
625,142,448
ATA security
SATA 6 Gb/s 256GB, 2.5-inch SATA SED Solid State Drive
73 g
256GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximum sequential read: Up to 460 MB/s
  • Maximum sequential write: Up to 260 MB/s
500,118,192
0° to 70°C (32° to 158°F) (case temp)
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
180GB 2.5-inch SATA Solid State Drive
78 g
180GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximum sequential read: Up to 550 MB/s
  • Maximum sequential write: Up to 520 MB/s
351,651,888
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive
73 g
128GB
7 mm (0.276 in)
70 mm (2.75 in)
SATA 3 (6 Gb/s)
  • Maximum sequential read: Up to 415 MB/s
  • Maximum sequential write: Up to 175 MB/s
250,069,680
  • ATA security
  • ATA-8 compliant
  • SATA 3.0
  • DIPM
  • TRIM
Optical drives
Drive
Access Times
Max Data Transfer Rate
Transfer Mode
Interface
Supported Media (read)
Supported Media (write)
Max Media Capacity (read)
Max Media Capacity (write)
Transport
DVD-ROM Drive
Random:
  • <140 ms CD (typical)
  • <160 ms DVD (typical)
  • 24X CD-ROM
  • 8X-DVD
UDMA Mode 5
Gen 1 SATA
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
None
8.5GB
Tray loading
DVD+/-RW SuperMulti DL Drive
Random:
  • 24X CD-ROM
  • 8X DVD
  • 24X CD-R
  • 24X CD-RW
  • 8X DVD+R
  • 8X DVD+RW
  • 8X DVD-R
  • 6X DVD-RW
  • 6X - DVD+R dual layer
  • 6X - DVD-R dual layer
  • 5X DVD-RAM
UDMA Mode 5
Gen 1 SATA
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
8.5GB
8.5GB
Tray loading
Network/Communications specifications
Intel 82579LM Gigabit Network Connection
Feature
Ethernet features
  • 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 10 Mb/s operation (10BASE-T; IEEE 802.3i; IEEE 802.3 clauses 13-14)
  • 100 Mb/s operation (100BASE-TX; IEEE 802.3u; IEEE 802.3 clauses 21-30)
  • 1000 Mb/s operation (1000BASE-T; IEEE 802.3ab; IEEE 8023. Clauses 40)
  • Auto-Negotiation (Automatic speed selection)
  • Full Duplex Operation at all Speeds, Half Duplex operation at 10 and 100 Mb/s
  • IEEE 802.1p QoS (Quality of Service) Support
  • IEEE 802.1q VLAN support
  • IEEE 802.3x Flow Control (IEEE 802.3 clauses 31-32; configurable)
  • IEEE 802.3az EEE(Energy Efficient Ethernet)
  • Jumbo Frame 9K
  • Auto MDI/MDIX Crossover cable detection
Power
ACPI compliant - multiple power modes
Management
Energy detect low power mode (Green Ethernet)
Performance
TCP/IP/UDP checksum offload (configurable)
Features
  • TCP/IP/UDP Checksum Offload (configurable)
  • Protocol Offload (ARP & NS)
  • Large send offload and Giant send offload
  • Receiving Side Scaling
  • MACSec Offload (802.3ae)
  • Intel vPro
  • iSCSI Boot
Manageability
  • Wake-on-LAN from standby and hibernation (Magic Packet and Microsoft Wake-Up Frame)
  • Wake-on-LAN from Off (Magic Packet only)
  • PXE 2.1 Remote Boot
  • Statistics Gathering (SNMP MIB II, Ethernet-like MIB, Ethernet MIB (802.3x, clause 30))
  • Comprehensive diagnostic and configuration software suite
  • Virtual Cable Doctor for Ethernet cable status
Interface1
PCI Express 1.1 x1 to fully support ASPM L0s/L1 and CLKREQ.
NIC device driver name
Intel 82579LM/82579V Ethernet Network Connection
1: Intel 82579 PCIe interface is not PCIe compliant. It operates at half of PCIe specification V1.1 (2.5 GT/S) speed.
V.92 56K Data/Fax Modem
Feature
Form factor
MDC 1.5 Daughtercard
Power management support
APM Revision 1.2, ACPI
Approvals/Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other Countries
Data mode capabilities
  • V.92 data
  • V.8bis
  • V.80
  • V44, V.42bis, MNP5 (Compression)
  • V.42 (LAPM, MNP2-4) (Error Correction)
  • Optional symbol rates:
    • 2800, 3429
    • Asymmetric Symbol rates
  • Synchronous primary channel data signaling rates:
    • 3600, 31200
    • Automatic rate re-negotiation
    • V.34
    • V.32bis
    • V.32
    • V.23
    • V.22bis
    • V.22
    • V.21
    • Bell 212A
    • Bell 103J
Fax mode capabilities
  • TIA/EIA-578-B (Class 1)
  • T.30, T.4 (Group 3)
  • V.17
  • V.29
  • V.27ter
  • V.21 Channel 2
  • T.31
Command set
  • V.250 (Partial)
  • TIA-602
  • Identification: +GMI, +GMM, +GMR
  • Port control: +IPR, +ICF, +IFC, +ILRR
  • Modulation: +MS, +MR, +MA
  • Error control: +ES, +ER, +EB, +ESR, +ETBM
  • Data compression: +DS, +DR
  • V.251
HP un2430 EV-DO/HSPA Mobile Broadband Module
Features
Technology/operating bands
  • GSM/GPRS/EDGE: 850 MHz (Cell), 900 MHz (EGSM), 1800 MHz(DCS), 1900 MHz (PCS)
  • UMTS/WCDMA with receive diversity: 2100 MHz (UTRA FDD Band I), 1900 MHz (UTRA FDD Band II), AWS (UTRA FDD Band IV), 900 MHz(UTRA FDD Band VIII), 850 MHz (UTRA FDD Band V)
  • 1xEVDO/1xRTT with receive diversity: 850 MHz (Band Class0-Cell), 1900 MHz (Band Class1-PCS)
Wireless protocol standards
  • GSM/GPRS/EDGE: Class A, Multi-slot class 10 operation, coding schemes CS1 - CS4 and MSC1 - MSC9.
  • UMTS/WCDMA: Release 99 and Release 6
  • CDMA: 1xEVDO Release 0 and Release A, IS-95A, IS-95B, IS-856, IS-2000
Wireless parametric standards
Meets or exceeds TIA/EIA IS-98-D
Maximum data rates
  • UMTS (HSPA) - 14.4 Mb/s (Download ), 5.76 Mb/s (Upload)
  • CDMA (EVDO Release A) - 3.1 Mb/s (Download), 1.8 Mb/s (Upload)
GPS
  • Standalone GPS enabled
  • gpsOneXTRATM
GPS bands
L1 - 1575.42 MHz
Maximum output power
  • GSM/GPRS/EDGE: 32 dBm (+/-1)
  • WCDMA: 24 dBm (+0.7/-2.3)
  • CDMA: 24 dBm (+0.7/-2)
Maximum power consumption
2750 mA (peak); 1100 mA (average)
Power consumption, Idle not connected
20 mA
Power management
  • USB selective suspend
  • Integrated notebook wireless button
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
Dimensions (Length x Width x Thickness)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, Operating
3.3 V +/- 10%
Temperature, Operating (from TIA/EIA/IS-98-D)
  • -30° to 70°C (-22° to 158°F) (full RF performance)
  • -30° to 75°C (-22° to 167°F) (reduced RF performance)
Temperature, Non-operating, 96 hours (from MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
Humidity, Non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP connection manager
LED activity
  • LED Off: Radio Off
  • Solid LED On: Radio On
HP hs2350 HSPA+ Mobile Broadband Module
Feature
  • UMTS/WCDMA: Release 99 and Release 7
  • Advanced Receiver Type 3i
Complies with 3GPP specifications
Maximum data rates
UMTS (HSPA) - 21 Mb/s (Download ), 5.76 Mb/s (Upload)
GPS
Standalone, A-GPS (Internet- and Network assisted)
GPS bands
1575.42 MHz (±1.023 MHz)
  • GSM/EDGE
  • GSM850 & GSM900 bands
  •  GPRS: +33 dBm ± 2 dBm (class 4)
  • EGPRS: +27 dBm ± 3 dBm (class E2)
  • DCS1800 & PCS1900 bands
  • GPRS: +30 dBm ± 2 dBm (class 1)
  • EGPRS: +26 dBm +4 / -3 dBm (class E2)
  • UMTS
  • UTRA FDD Bands
  • +24 dBm +4/-3 dBm (class 3)
2000 mA (peak); 600 mA (average)
Power consumption, sleep mode
5 mA
Power management
Antenna type
Form factor
<12 g
Voltage, Operating
3.3 V+/- 9%
  • -10° to 65°C (14° to 149°F) (full RF performance)
  • -10° to 75°C (14° to 167°F) (reduced RF performance)
-30° to 85°C (-22° to 185°F)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
HP Connection Manager
LED activity
Intel Centrino Advanced-N 6205 (2 x 2)
Feature
Wireless LAN standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Cisco Compatible Extensions Program compliant with Microsoft Windows, Windows Vista and XP
Frequency band
2.4 GHz and 5 GHz
Antenna structure
2 transmit; 2 receive (2 x 2)
Data rates
  • 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11b: 1, 2, 5.5, 11 Mb/s
  • 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 66 possible data rates, ranging from 6 Mb/s to 300 Mb/s, depending on the combination of Bandwidth, Modulation Coding Scheme, and Guard Interval used, as defined in IEEE 802.11n specification
Modulation
  • Direct Sequence Spread Spectrum
  • DBPSK, DQPSK, CCK, OFDM, BPSK, QPSK, 16-QAM, 64-QAM
Security
  • Authentication: WPA and WPA2, 802.1x (EAP_TLS, TTLS, PEAP, LEAP, EAP-FAST)
  • Authentication Protocols: PAP, CHAP, TLS, GTC, MS-CHAP, MS-CHAPv2
  • Encryption: 64 and 128-bit WEP, AES-CCMP, CKIP, TKIP
  • Support for Cisco Security Features (proven compatibility with Cisco Aironet infrastructure products through the Cisco Compatible Extensions Program Version 4) with Microsoft Windows Vista and XP only.
Sub-channels
Multinational support with frequency bands and channels compliant to local regulations.
Media access protocol
CSMA/CA (Collision Avoidance) with ACK
Network architecture models
  • Ad-hoc (Peer to Peer)
  • Infrastructure (Access Point Required)
Roaming
IEEE 802.11 compliant roaming between 2.4GHz band Access Points
Output power (for CCK and OFDM)
17 dBm max
Power consumption
  • Transmit: 2.3 W (max, with two spatial streams)
  • Receive: 1 W (max with two spatial streams)
  • Idle mode: 35 mW (average)
  • Radio Off: 20 mW (max)
Power management
  • ACPI compliant power management
  • 802.11 compliant power saving mode
Receiver sensitivity
  • 54 Mb/s: -76 dBm
  • 6 Mb/s: -92 dBm
Antenna connections
2 U.FL type connectors, 50 ohm nominal impedance
Form factor
<3.4 g (0.0075 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Voltage, Operating
3.3 V+/- 9%
Temperature
  • Operating: 0° to 80°C (32° to 176°F)
  • Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
  • Operating: 10% to 90% (non-condensing)
  • Non-operating: 5% to 90% (non-condensing)
Altitude
  • Operating: 3,048 m (0 to 10,000 ft)
  • Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
Atheros AR9485 802.11 b/g/n WiFi Adapter (1 x 1)
Feature
Wireless LAN Standards
  • IEEE 802.11a
  • IEEE 802.11b
  • IEEE 802.11g
  • IEEE 802.11n
Interoperability
  • Wi-Fi certified
  • Windows Vista and XP
Frequency band
2.4 GHz and 5 GHz
Data rates
  • 802.11a/g: 6, 9, 12, 18, 24, 36, 48, 54 Mb/s
  • 802.11n: 6, 6.5, 9, 12, 13, 13.5, 18, 19.5, 24, 26, 27, 36, 39, 40.5, 48, 52, 54, 58.5, 65, 78, 81, 104, 108, 117, 121.5, 130, 135, 162, 216, 243, 270, 300 Mb/s
Frequency support
  • 20 MHz: 2.4 GHz and 5 GHz bands
  • 40 MHz: 2.4 GHz and 5 GHz bands
Modulation
Security
  • Supports 64- and 128-bit WEP, WPA, WPA2, hardware-accelerated AES, 802.1x authentication types EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, LEAP, EAP-FAST.
Sub-channels
Roaming
  • 17 dBm max
  • 15 dBm , nominal
Power consumption
  • Idle associated: 250 mW
  • Idle unassociated: 150 mW
  • Transmit/Receive 20 MHz channel: 2.0 W (max)
  • Transmit/Receive 40 MHz channel: 2.0 W (max)
Power management
  • 270 Mb/s: -68 dBm
  • 54 Mb/s: -72 dBm
  • 11 Mb/s: -85 dBm
  • 1 Mb/s: -96 dBm
Antenna connections
High efficiency dual band antenna with spatial diversity, mounted in the display enclosure
Form factor
PCI-Express Half-MiniCard
6 g (0.013 lb)
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Voltage, Operating
3.3 V+/- 10%
Temperature
  • Operating: -10° to 65°C (14° to 149°F)
Humidity
Altitude
LED activity
HP Integrated Module with Bluetooth 4.0+EDR Wireless Technology
Feature
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available channels
79 (1 MHz) available channels
Data rates and throughput
  • 3 Mb/s data rate; throughput up to 2.17 Mb/s
  • Synchronous Connection Oriented links up to 3, 64 kb/s, voice channels
  • Asynchronous Connection Less links 2178.1 kb/s/177.1 kbps asymmetric or 1306.9 kb/s symmetric
Security
Full support of Bluetooth Security Provisions
Link topology
Point to Point, Multipoint Pico Nets up to 7 slaves
Bluetooth Software Supported
  • Broadcom Bluetooth for Windows
  • Microsoft Windows Bluetooth Software
  • USB 2.0 compliant
  • Microsoft Windows Plug and Play compliant
Electrical interface
Range
Upto 10 m (33 ft)
Antenna
Internally integrated within module
Power consumption
  • Peak (Tx): 264 mW
  • Peak (Rx): 231 mW
  • Sleep: <1 mW
Power management
  • Microsoft Windows ACPI, and USB Bus Support
  • Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniff
Better than -20 dBM at 0.1 % raw bit error rate
Dimensions
Temperature
  • Operating: -10° to 70°C (14° to 158°F)
  • Non-operating: -40° to 100°C (-40° to 212°F)
Humidity
  • Operating: 0% to 90%
  • Non-operating: 0% to 95%
Altitude
  • Operating: 4,572 m (15,000 ft)
  • Non-operating: 12,192 m (40,000 ft)
Certifications
  • All necessary regulatory approvals for supported countries, including: FCC (47 CFR) Part 15C, Section 15.247 & 15.249
  • ETS 300 328, ETS 300 826 Low Voltage Directive IEC950 UL, CSA, and CE Mark
  • Low Voltage Directive IEC950
  • UL, CSA, and CE Mark
Bluetooth profiles supported
  • Serial Port Profile (SPP)
  • Service Discovery Application Profile (SDAP)
  • Dial-Up Networking (DUN)
  • Generic Object Exchange Profile (GOEP)
  • Object Push Profile (OPP)
  • File Transfer Profile (FTP)
  • Synchronization Profile (SYNC)
  • Hard Copy Cable Replacement (HCRP)
  • Personal Area Networking Profile (PAN)
  • Human Interface Device Profile (HID)
  • FAX Profile (FAX)
  • Basic Imaging Profile (BIP)
  • Headset Profile (HSP)
  • Hands Free Profile (HFP)
  • Advanced Audio Distribution Profile (A2DP)
System configuration
Energy Consumption
115 V ac
230 V ac
100 V ac
Normal operation
12.21 W
12.96 W
12.29 W
 Sleep (Energy star low)
0.61W
0.72 W
0.59 W
Off
0.37 W
0.42 W
0.35 W
Heat dissipation
Normal operation
42 BTU/hr
44 BTU/hr
42 BTU/hr
Sleep
2 BTU/hr
2 BTU/hr
2 BTU/hr
Off
1 BTU/hr
1 BTU/hr
1 BTU/hr
Declared Noise Emissions (in accordance with ISO 7779 and ISO 9296)
System fan Off
Sound power (LWAd, bels)
Sound pressure (LpAm, decibels)
Idle
23
Fixed disk
24
Audio/Multimedia
Feature
Implementation
IDT 92HD80 High Definition CODEC
Function key volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone In
Stereo
Headphone/Line Out
Stereo
Integrated Microphone
Yes, dual digital microphone array
Audio output quality
Frequency response
20 Hz to 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling rate(s)
8 kHz to 48 kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Internal stereo speaker
Power rating
2 W
Impedance
4 ohms
Power specifications
HP 65-W Smart AC adapter
Feature
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
  • 100 to 240 V ac
  • Input efficiency: 87% min at 115 VAC
  • Input frequency range: 47 to 63 Hz
  • Input AC current: 1.7 A at 90 V ac, 0.85 A at 180 V ac PFC Version
Output
  • Output power: 65W
  • DC Output Voltage: 18.5 V
  • Hold-up time: 5 ms at 115 V ac input
  • Output current limit: <11 A, Over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
  • Operating temperature : 0° to 40°C (32° to 104°F)
  • Non-operating tempeture (storage): -20° to 65°C (-4° to 149°F)
  • Altitude: 0 to 3,048 m (0 to 10,000 ft)
  • Humidity: 20% to 80%
  • Storage humidity: 10% to 90%
EMI and safety certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals - C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B, CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C (77°F) ambient condition.
Battery specifications
Battery
Dimensions (H x W x L)
Weight (max)
Cells/Type
Energy
Temperature
Battery Re-Charge Time
Fuel Gauge LED
Optional Travel Battery Available
HP 9-cell (100 Whr) Lithium-Ion Primary battery
2 x 6.6 x 20.5 cm (0.8 x 2.4 x 8.1 in)
0.488 kg (1.1 lb)
Lithium-Ion
  • Voltage 11.25 V
  • Amp-hour capacity 8.85 Ah
  • Watt-hour capacity 100 Wh
  • Operating (Charging) 0° to 45°C (32° to 113°F)
  • Operating (Discharging) -10° to 50°C (14° to 122°F)
  • Non-operating -20° to 50°C (-4° to 122°F)
  • System in Off or Standby Mode: 3.5 to 5 hours
  • System On: 4 to 7 hours
No
1 year
Yes
6-Cell (62 Whr) Lithium-Ion battery
2.0 x 5.1 x 21.1 cm (0.8 x 2.0 x 8.3 in)
0.325 kg (0.72 lb)
6-cell Lithium-Ion
Watt-hour capacity: 62 Wh
  • Operating (Discharging) -10° to 60°C (14° to 140°F)
  • Non-operating -20° to 60°C (-4° to 140°F)
System in Off or Standby Mode: 2.5 hours
1 year
Yes
HP 6-cell (55 Whr) Long Life Battery
2.0 x 4.7 x 20.5 cm (0.8 x 1.8 x 8.0 in )
0.323 kg (0.72 lb)
Lithium-Ion
  • Voltage 10.8 V
  • Amp-hour capacity 5.1 Ah
  • Watt-hour capacity 55 Wh
  • System in Off or standby mode: 2.5 hours
  • System On:3 to 5 hours
No
3 years
Yes
Physical specifications
Specification
Starting at 1.65 kg (3.62 lb) without optical drive
Dimensions (W x D x H)1
30.5 x 20.9 x 2.7 cm (12.02 x 8.23 x 1.08 in) (at front)
1: Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 3-cell battery, lightest hard drive/SSD, 1 SODIMM, and weight saver. Weight varies by configuration and components.
Software/OS
Feature
Preinstalled Software with Windows Operating System
  • Microsoft Office Starter: reduced-functionality Word and Excel only, with advertising. No PowerPoint or Outlook.
  • Adobe Flash
  • PDF Complete, Corporate Edition
  • WinZip Basic
  • Corel WinDVD
  • Roxio Secure Burn
  • Roxio MyDVD Business 2010
Environmental specifications
Specification
Temperature
  • Operating:
    • 0° to 35°C (32° to 95°F) (not writing optical)
    • 5° to 35°C (41° to 95°F) (writing optical)
  • Non-operating: -20° to 60°C (-4° to 140°F)
Relative humidity
  • Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
  • Operating: 40 G, 2 ms, half-sine
  • Non-operating: 200 G, 2 ms, half-sine
Random vibration
  • Operating: 0.75 g
  • Non-operating: 1.50 g
Altitude (unpressurized)
  • Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
  • Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
Specification
Eco-Label Certifications
US Energy Star
IT ECO declaration
EPEAT Gold where HP registers commercial desktop products
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
