HP Z220 Small Form Factor Workstation - Specifications
System specifications
Specification
System board form factor
ATX 244 x 305 mm (9.6 x 12 in)
PCI Express connectors
  • 1 PCI Express Gen3 x16 LP slot (x16 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x16 LP slot (x4 electrical/x16 mechanical)
  • 1 PCI Express Gen2 x1 LP slot (x1 electrical/x1 mechanical)
HD Integrated audio
Yes
Flash ROM
Yes
CPU Fan header
Not applicable - passive CPU heatsink
Chassis fan header
Yes
Front control panel/speaker header
Yes
CMOS Battery holder - lithium
Yes
Integrated trusted platform module
Integrated TPM 1.2
The TPM module disabled where restricted by law, that is: Russia.
Power supply headers
Yes
Power switch, power LED and hard drive LED header
Yes
Clear password jumper
Yes
Keyboard/Mouse
USB or PS/2
Hood lock header
Yes (optional)
Built-in Self Test (BIST) LED
No
Surge tolerant full ranging power supply (withstands power surges up to 2000 V)
Yes
Physical specifications
Specification
Dimensions (H x W x D)
  • Standard desktop orientation: 100 x 338 x 381 mm (3.95 x 13.3 x 15.0 in)
  • Optional SFF Tower orientation (excluding stand dimension): 338 x 100 x 381 mm (13.3 x 3.95 x 15.0 in)
Weight (approximate)
  • Typical weight: 7.5 kg (16.5 lbs)
  • Shipping weight: 8.1 kg (17.86 lbs)
  • Maximum Supported Weight (desktop orientation): 35 kg (77 lb)
Configured with 1 3.5" hard drive, 1 optical drive, 2 DIMMs and 1 NVIDIA NVS 300 graphics card.
Electrical specifications
Specification
Operating voltage range
90 to 264 V ac
Rated voltage range
100 to 240 V ac
Rated line frequency
50 to 60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
4 A @ 100-240 V
Heat dissipation
  • Typical: 138 kg-cal/hr (546 btu/hr)
  • Maximum: 237 kg-cal/hr (941 btu/hr)
Power supply fan
92 x 25 mm variable speed
ENERGY STAR qualified (configuration dependent)
Yes
Environmental specifications
Specification
Operating temperature
5° to 35°C (40° to 95°F)
Non-operating temperature
-40° to +60°C (-40° to +140°F)
Operating relative humidity
8% to 85%, non-condensing
Non-operating relative humidity
8% to 90%, non-condensing
Operating altitude
3000 m (10,000 ft)
Non-operating altitude
9100 m (30,000 ft)
Cooling
Above 1524 m (5,000 ft) altitude, maximum operating temperature is de-rated by 1°C (1.8°F) per 305 m (1000 ft) elevation increase
Safety certifications
Specification
Energy star qualified (config dependent)
Yes
80 Plus compliant
Yes, gold
CECP Compliant at 220 V
Yes, configuration dependent
FEMP Standby power compliant
Yes, with Wake-on-LAN disabled
Country: Flag Thailand
