HP 2012 120W/230W Advanced Docking Station Product Specifications
Product description
HP Advanced Docking Stations include a range of convenient expansion solutions that easily connect to the HP Business Notebook and enable connectivity to a range of peripherals that provide port replication, cable management, and future expandability.
Product features
Feature
Docking post
Two docking posts for proper connection
Connectors and buttons
  • One docking connector
  • Visual alignment indicator
  • Power button and power light
  • Eject button and docking light
  • One monitor stand
  • Two DisplayPort 1.2 connector
  • One VGA connector
  • Two DVI-D connectors
Ports
  • Four USB 3.0 ports (Always-On), two USB 2.0 ports (one Always-On, one powered)
  • Always-On USB port
  • Powered USB port
  • eSATA port
Audio and network connectors
  • Audio and Ethernet ports
  • Line-in jack
  • Headphone jack
Legacy connectors
  • Mouse
  • Keyboard
  • Serial and parallel connectors
Smart adapters
  • HP 120-W Smart AC Adapter
  • HP 230-W Smart AC Adapter
Computer, docking station, and monitor must all support USB 3.0 and DisplayPort 1.2 to benefit from the advanced speeds or features that these technologies provide. If one of the devices does not support these technologies, end user will still have USB 2.0 and DisplayPort 1.1 functionality.
Electrical specifications
Specification
Rated voltage
100 to 240 V
Rated current
2.5 A
Line frequency
50 to 60 Hz
Physical specifications
Specification
Dimensions (H x W x D)
6.6 x 27.05 x 26.0 cm (2.60 x 10.65 x 10.24 in)
1.64 kg (3.61 lb)
Environmental specifications
Specification
Temperature
Operating:
  • 10° to 35°C (50° to 95°F)
Non-operating:
  • -10° to 60°C (14° to 140°F)
Relative humidity1
5% to 90% relative humidity, 38.7°C (101.6°F) maximum wet bulb temperature
Maximum altitude
Operating:
  • 0 to 3,048 m (0 to 10,000 ft)
Non-operating:
  • 0 to 9,144 m (0 to 30,000 ft)
Shock
Operating:
  • Half-sine: 10 G, 11 ms
Non-operating:
  • Half-sine: 60 G, 11 ms
Dynamic vibration
Operating:
  • 0.5 G (rms) zero-to-peak, 10 to 500 Hz, 0.25 oct/min sweep rate
Non-operating:
  • 1.0 G (rms) zero-to-peak, 10 to 500 Hz, 0.5 oct/min sweep rate
1: Relative humidity mentioned is for non-operating environment.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
