HP W2072a LCD Monitor - Product Specifications
The HP W2072a is a 50.8 cm (20 inch) LED backlit LCD monitor.
Figure : Photo of the HP W2072a LED backlit LCD monitor
Product numbers
A3M50AA / A3M50AS / B5M13AA / B5M13AS / B5W13AV
Features
The W2072a LED backlit LCD monitor has the following features:
  • DVI-D and VGA video input connectors
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Security lock
Technical specifications
LED feature
Specification
Display size
50.8 cm (20 inch) diagonal
Panel active area (width x height): 44.3 cm x 24.9 cm (17.4 inches x 9.8 inches)
Display type
TN (LCD) with LED backlighting
Aspect ratio
16:9
Brightness
200 nits
Input terminal
1 DVI-D connector
1 VGA connector
Speakers output power
1 Watt per channel
Scanning frequency
Horizontal scan range 24-83 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle (typical): 90 degrees
Vertical viewing angle (typical): 50 degrees
Recommended resolution (H x V)
1600 x 900 @ 60 Hz (same as max resolution)
Static contrast ratio
Up to 600:1
Dynamic contrast ratio
Up to 3,000,000:1
Response time
5 ms
Pixel pitch
0.277mm
Pixels per inch
91.8
Color gamut
72%
HDCP (High-bandwidth Digital Content Protection)
Yes
Power source - AC/DC adapter
Internal power supply
Power consumption: 26 Watts max power consumption (20 Watts typical power consumption) , 0.5 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 80% RH (non-condensing)
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 5% RH through 95% RH (non-condensing)
Dimensions
H x W x D (unpacked):
35.7 x 47.7 x 17 cm (14 x 18.8 x 6.7 inches)
Unpacked: 3.5 Kg (7.7 lbs)
