Document ID: c03333068
Version: 1
NOTEBOOK - System BIOS Update F.26 for 2560p, 8560w, 2760p
Release date : 15-May-2012
Last updated : 10-Jan-2018
รายละเอียดการเปลี่ยนแปลง
  • Added support for dual USB keyboards in the DOS environment.
  • Added location, manufacturer, size, and speed for each memory slot in the F10 BIOS setup.
  • Added support for Wake on LAN (WOL) with DC power.
  • Fixed an issue where the BIOS cannot be flashed unattended if the BIOS password is larger than 16 characters. This issue occurs only when the BIOS is flashed in delay mode.
  • Fixed an issue where the automatic DriveLock password will not be accepted after a system restart.
  • Fixed an issue where some USB keyboards would not work in the pre-operating system environment.
  • Added a "Require acknowledgment of battery errors" message to keep the 601-602 battery error message displayed during POST until the user acknowledges the message by pressing a key to continue.
  • Fixed an issue where the system fails to resume from Standby or Hibernation in DC mode with the insertion of a specific media card reader. Note that this issue only occurs in DC mode with Microsoft Windows XP.
SUPPORT URL
Get the latest BIOS update from the HP Software dowload site for the 2560p, 8560w and 2760p.
REASON FOR CHANGE
To implement changes under "Details of Change."
IMPACT OF CHANGE
None.
Components affected:
HP EliteBook 2560p Notebook PC, HP EliteBook 8560w Mobile Workstation, HP EliteBook 2760p Tablet PC
DATE OF CHANGE
Effective date : 18-Jun-2012
Hardware platforms affected : HP EliteBook 2560p Notebook PC, HP EliteBook 2760p Tablet PC, HP EliteBook 8560w Mobile Workstation
