The HP S1933 18.5-inch Widescreen LCD Monitor comes with a low power consumption
panel that uses less power and contains 50% less mercury, and with the display glass that is
arsenic-free.
- ${title}
- ${title}
- ${title}
- ${title}
HP S1933 18.5-inch Widescreen LCD Monitor - Overview
Product description
Product features
Feature
Panel
47.0 cm (18.5 in) wide-aspect active matrix Thin Film Transistor (TFT)
47.0 cm (18.5 in) widescreen; diagonally measured
Screen opening (W x H)
40.9 x 23 cm (16.1 x 9.05 in)
Panel type
TN
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal and 55° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
200 nits (cd/m2)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio (typical)1
5000:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.3 mm
Backlight lamp life (to half brightness)
50,000 hours
Color gamut
57%
Color support
Up to 16.7 million colors
Horizontal frequency
30 to 83 kHz
Vertical frequency
55 to 75 Hz
Native resolution
1366 x 768 @ 60 Hz
User programmable modes
Yes (10)
Anti-glare
Yes
Anti-static
Yes
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 ohms
Sync input
TTL separate synch
Tilt range
-4° to +18°
Swivel range
No
Height adjustable
No
Pivot rotation
No
note: |
Links to product specification and warranty information
Links to product QuickSpecs
Information for this overview is taken from the product QuickSpecs. To access the complete QuickSpecs for this product, select the desired link from the following list:
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
