HP LV1911 18.5-inch LED Backlit LCD Monitor Product Specifications
Product description
Slim, 18.5-inch diagonal monitor that delivers impressive, productive computing in a whole new way. Enhanced brightness, contrast and clarity with the power of a Mercury-free LED backlit panel screen. The simple, “plug and play” connectivity relieves IT tie-ups with a quick start-up and go solution.
Product features
Feature
Type
TN (Twisted Nematic) LED Backlit LCD
47 cm (18.5 in) widescreen; diagonally measured
Active area (W x H)
40.98 x 23.04 cm (16.13 x 9.07 in.)
Aspect ratio
16:9
Viewing angle (typical)1
Up to 90° horizontal/50° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
200 cd/m2 (nits)
Contrast ratio (typical)1
600:1
Dynamic contrast ratio (typical)1
3,000,000:1
Response rate (typical)1
5 ms (on/off)
Pixel pitch
0.3 mm
Pixels Per Inch (PPI)
84.7
Backlight lamp life (to half brightness)1
30,000 hours
Color gamut (typical)1
68%
Color support2
16.7 million colors
Anti-glare
Yes
Tilt range
-5° to +19°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
Languages
  • German
  • Simplified Chinese
  • Traditional Chinese
  • Japanese
  • English
  • Spanish
  • French
  • Italian
  • Netherlands
  • Portuguese
  1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
  2. With the use of FRC technology.
Technical specifications
On Screen Display (OSD) controls
Buttons or switches
  • Power (on/off)
  • 4-button OSD (Menu, Minus, Plus, OK)
User controls
  • Brightness
  • Contrast
  • Color (6500k, 9300k, 5000k, custom)
  • Image control
  • OSD control
  • Management
  • Language
  • Factory reset
  • Source control (on select model)
  • Exit
Signal interface/Performance
Horizontal frequency
24 to 83 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1366 x 768 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/Other inputs
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
(1) VGA (15-pin D-sub)
Video cable lengths
1.8 m (6 ft)
Audio
No
Electrical specifications
Input power
100 – 240 V ac, 50 or 60 Hz
Typical power consumption
17 W
Maximum power consumption
19 W
Power saving
< 0.5 W (Sleep)
Power cable length
1.9 m (6.2 ft)
Physical specifications
Dimensions (W x D x H)
  • Unpacked w/ stand
    44.61 x 17.02 x 33.95 cm (17.56 x 6.7 x 13.37 in)
  • Unpacked w/o stand (head only)
    44.61 x 4.75 x 28.15 cm (17.56 x 1.87 x 11.08 in)
  • Packaged
    51.8 x 35.2 x 11 cm (20.39 x 13.86 x 4.33 in)
  • Base area (footprint)
    17.02 x 17.99 x 1.9 cm (6.7 x 7.08 x 0.75 in)
  • Head only
    2.3 kg (5.07 lb)
  • Unpacked
    2.7 kg (5.95 lb)
  • Packaged
    3.7 kg (8.16 lb)
Environmental specifications
Temperature – operating
5° to 35°C (41° to 95°F)
Temperature – non-operating
-20° to 60°C (-4° to 140°F)
Humidity – operating
20% to 80% non-condensing
Humidity – non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude – operating
+0 to 3658 m (12,000 ft)
Altitude – non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass1
Yes
BFR/PVC free2
No
Mercury free
Yes
  1. Arsenic and its compounds were not detected using US EPA Test Methods 3052 & 3052/6010b by ICP or ICP-AES.
  2. Meets the evolving definition of 'BFR/PVC-free' as set forth in the "iNEMI Position Statement on the 'Definition of Low-Halogen' Electronics (BFR/CFR/PVC-Free)'". Plastic parts contain <1000 ppm (0.1%) of bromine [if the Br source is from BFRs] and <1000 ppm (0.1%) of chlorine [if the Cl source is from CFRs or PVC or PVC copolymers]. All printed circuit board (PCB) and substrate laminates contain bromine/chlorine total <1500 ppm (.15%) with a maximum chlorine of 900 ppm (.09%) and maximum bromine being 900 ppm (.09%). External cables (power, video and USB) are not BFR/PVC-free. Service parts after purchase may not be BFR/PVC-free.
Certification and compliance
Certifications
  • UL
  • CUL
  • CE
  • FCC Class B
  • NOM
  • ICES
  • Tick
  • BSMI
  • CCC
  • TUV/S
  • ISC
  • PSB
  • China Energy Label Grade 1
  • Microsoft WHQL Certification
  • US ENERGY STAR
  • EPEAT Silver1
1. EPEAT Silver where HP registers commercial display products. Click here to access the registration status in your country.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
