HP LaserJet Pro 400 Printer M401 - Use HP Web Services applications (LCD control panel)
  1. On the control panel, press the OK button.
  2. Select the HP Web Services menu, and then press the OK button.
After you download an application from the HP ePrintCenter Web site, it is available in the Apps menu on the product control panel.
