    Windows 11 Upgrade Guide
HP V191 18.5-inch LED Backlit LCD Monitor - Specifications
Physical specifications
Dimensions (W x D x H)
  • Unpacked w/ stand
    44.61 x 17.02 x 33.95 cm (17.56 x 6.7 x 13.37 in)
  • Unpacked w/o stand (head only)
    44.61 x 4.75 x 28.15 cm (17.56 x 1.87 x 11.08 in)
  • Packaged
    51.8 x 35.2 x 11 cm (20.39 x 13.86 x 4.33 in)
  • Base area (footprint)
    17.02 x 17.99 x 1.9 cm (6.7 x 7.08 x 0.75 in)
  • Head only
    2.3 kg (5.07 lb)
  • Unpacked
    2.7 kg (5.95 lb)
  • Packaged
    3.7 kg (8.16 lb)
Technical specifications
On Screen Display (OSD) controls
Buttons or switches
  • Power (on/off)
  • 4-button OSD (Menu, Minus, Plus, OK)
User controls
  • Brightness
  • Contrast
  • Color (6500k, 9300k, 5000k, custom)
  • Image control
  • OSD control
  • Management
  • Language
  • Factory reset
  • Source control (on select model)
  • Exit
Signal interface/Performance
Horizontal frequency
24 to 83 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1366 x 768 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 1366 x 768 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 720 x 400 @ 70 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
140 MHz
User programmable modes
Yes (10)
Anti-glare
Yes
Default color temperature
6500 K
Video/Other inputs
Plug and play
Yes
Input connectors
VGA (analog)
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
(1) VGA (15-pin D-sub)
Video cable lengths
1.8 m (6 ft)
Audio
No
Electrical specifications
Input power
100 – 240 V ac, 50 or 60 Hz
Typical power consumption
17 W
Maximum power consumption
19 W
Power saving
< 0.5 W (Sleep)
Power cable length
1.9 m (6.2 ft)
Environmental specifications
Temperature – operating
5° to 35°C (41° to 95°F)
Temperature – non-operating
-20° to 60°C (-4° to 140°F)
Humidity – operating
20% to 80% non-condensing
Humidity – non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude – operating
+0 to 3658 m (12,000 ft)
Altitude – non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlights
Yes
CCFL panel
No
Arsenic-free glass1
Yes
BFR/PVC free2
No
Mercury free
Yes
  1. Arsenic and its compounds were not detected using US EPA Test Methods 3052 & 3052/6010b by ICP or ICP-AES.
  2. Meets the evolving definition of 'BFR/PVC-free' as set forth in the "iNEMI Position Statement on the 'Definition of Low-Halogen' Electronics (BFR/CFR/PVC-Free)'". Plastic parts contain <1000 ppm (0.1%) of bromine [if the Br source is from BFRs] and <1000 ppm (0.1%) of chlorine [if the Cl source is from CFRs or PVC or PVC copolymers]. All printed circuit board (PCB) and substrate laminates contain bromine/chlorine total <1500 ppm (.15%) with a maximum chlorine of 900 ppm (.09%) and maximum bromine being 900 ppm (.09%). External cables (power, video and USB) are not BFR/PVC-free. Service parts after purchase may not be BFR/PVC-free.
Certification and compliance
Certifications
  • UL
  • CUL
  • CE
  • FCC Class B
  • NOM
  • ICES
  • Tick
  • BSMI
  • CCC
  • TUV/S
  • ISC
  • PSB
  • China Energy Label Grade 1
  • Microsoft WHQL Certification
  • US ENERGY STAR
  • EPEAT Silver1
1. EPEAT Silver where HP registers commercial display products. Click here to access the registration status in your country.
