HP Scanjet Scanner series - Mac OS X: Unable to Scan After Switching Users On the Macintosh
Issue
Mac OS X supports having multiple users on one Macintosh PC. The OS also allows users to switch between accounts without rebooting the Macintosh PC. This can be done with Fast User Switching or by Logging Out as one user and Logging in as another user. The HP Scan software will crash with the error HP Scan quit unexpectedly if the Mac OS has switched users without rebooting the Macintosh PC in between.
Solution
To allow scanning between multiple users on the Mac OS, the Macintosh PC must be powered off when the first users is done and then powered on and logged in as the second user.
Only the first user to log in after a reboot will be able to scan.
