    Looking for Site Help?
HP Z620 Workstation - Removing and Replacing Sound Card
This document is provided to assist in removing and replacing the sound card for the HP Z620 Workstation.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Parts required
The replacement part number will vary depending on the sound card that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
PCIe SoundBlaster (Creative Labs) X-Fi Titanium audio card - With advanced hardware accelerated digital effects processing with seven speaker support
493346-001 (Modified)
Yes
For customers in countries/regions with RoHS legislation (e.g. EU, China, etc.) restricting the use of hazardous substances in electrical equipment. The use of the "Original" spare part is regulated by RoHS legislation. If the unit contains a part that is labeled with the "Modified" spare number, the "Modified" spare part must be ordered as the replacement part. If the unit contains a part that is labeled with the "Original" spare number, please order the "Original" spare number as the replacement part. In this case, either the "Original" or the "Modified" spare number may be shipped which will not affect performance or functionality of the unit.
Summary of instructions
To view a video demonstrating the procedure for removing the sound card, click here to view the HP Services Media Library and then click on Remove/Replace videos. On the new window, select Sound card from the menu on the upper left hand side of the screen.
Sound card removal
This video was developed using a pre-production version of the workstation. The chassis and parts shown might not exactly match the current production version, but the part removal and replacement steps are the same.
    Failure to comply with the precautions could result in damage to the product or loss of data.
  2. Disconnect the front audio cable from the card.
  3. Press on the two release latches and rotate the PCI retention clamp until it is fully open.
  4. Lift straight up on the card to remove it from the slot.
    If customer is not replacing the card with another card, cover the open slot on the PCI bulkhead with a metal slot cover.
Sound card replacement
  1. If customer is installing a new sound card, remove the slot cover from the appropriate slot on the PCI bulkhead.
  2. Align the connectors on the card with the slot on the system board.
  3. Press down on the card until it is fully seated.
  4. Rotate the PCI retention clamp down over the PCI bulkhead.
  5. Press the two PCI retention clamp tabs on the rear of the chassis until they lock into place.
  6. Connect the front audio cable to the card.
  7.   note:
    Please refer to the product-specific maintenance and service guide at for any future technical information and/or installation guidelines for this component. Click here to refer the product-specific maintenance and service guide.
Country: Flag Thailand
