Document ID: c03284084
Version: 1
HP Notebook PCs - Certain External Display Panels Do Not Display at Full Screen With DP or DVI Connection
Release date : 16-Apr-2012
Last updated : 16-Apr-2012
DESCRIPTION
An external display panel connected to the notebook (DP to DVI) does not display the video image at full screen. The image is centered on a black field. However, the display panel resolution settings indicate that the notebook is correctly configured with the correct resolution.
SCOPE
HP EliteBook 8460p Notebook PC
RESOLUTION
To resolve this issue, download and install the following SoftPaq.
Softpaq Description
Download
Intel Video Driver and Control Panel
VERSION: 6.14.10.5394
Note: A more recent version of this software may be available. Check for updated drivers and software for your computer at http://www.hp.com/.
Hardware platforms affected : HP EliteBook 8460p Notebook PC
Operating systems affected : Microsoft Windows XP Professional Edition
Support Communication Cross Reference ID : IA03284032
