Document ID: c03280723
Version: 1
Advisory: HP Z1 Workstation - Does Not Return from Sleep/Hibernate from Graphical Mode with RHEL 6.2 Forcing Reboot.
Release date : 11-Apr-2012
Last updated : 11-Apr-2012
DESCRIPTION
Symptoms:
Use of either the suspend (sleep) or hibernate state from a graphical mode run state does not work correctly. The system may hang with no solution but to reboot (and thus, lose work and/or data).
Configuration:
HP Z1 using Intel HD [integrated] graphics. (Not an issue with NVIDIA graphics.)
RHEL 6.2 operating system installed (32- or 64-bit) in "basic video driver" mode.
sourceInformation
SCOPE
Information in this document applies to the listed systems configured as follows:
Systems:
  • HP Z1 Workstation
Operating Systems:
  • Red Hat Enterprise Linux 6 (x86)
  • Red Hat Enterprise Linux 6 (x86_64)
RESOLUTION
No known solution supported by HP.
The recommended workaround is to disable and/or avoid Suspend and Hibernate. System administrator can set defaults for all users to avoid this state. It is recommended to change the power management defaults immediately after OS installation and/or HP driver CD application.
Hardware platforms affected : HP Z1 Workstation
Operating systems affected : Red Hat Enterprise Linux (Itanium) (deleted) Red Hat Enterprise Linux 6 (x86) (deleted)
Support Communication Cross Reference ID : IA03280723
Country: Flag Thailand
