HP LaserJet Pro 300/400 color M351/M451 Series Printer - Save custom print settings for reuse with Windows
Use a printing shortcut with Windows
  1. On the File menu in the software program, click Print.
    Figure : File menu
  2. Select the product, and then click the Properties or Preferences button.
    Figure : Print dialog box
  3. Click the Printing Shortcuts tab.
    Figure : Shortcuts tab
  4. Select one of the shortcuts, and then click the OK button.
    When you select a shortcut, the corresponding settings change on the other tabs in the printer driver.
Create printing shortcuts
    Figure : File menu
  4. Select an existing shortcut as a base.
    Always select a shortcut before adjusting any of the settings on the right side of the screen. If you adjust the settings and then select a shortcut, all your adjustments are lost.
  5. Select the print options for the new shortcut.
  6. Click the Save As button.
    Figure : Shortcuts
  7. Type a name for the shortcut, and click the OK button.
Country: Flag Thailand
