    Fix Windows 10 Update Issues
Document ID: c03246810
Version: 1
HP Notebook PCs - Quick Launch or Synaptics User Interface Does Not Turn Off Touchpad Buttons
Release date : 19-Mar-2012
Last updated : 19-Mar-2012
DESCRIPTION
The touch pad buttons will not be disabled using the Quick launch touch pad feature or the Synaptics touchpad application. The touchpad will disable but the touchpad buttons will not.
SCOPE
HP EliteBook 8440p Notebook PC
HP EliteBook 8540p Notebook PC
HP EliteBook 8740w Mobile Workstation
RESOLUTION
The touchpad is functioning as intended per hardware configurations. The pointstick and touchpad buttons are interdependent and can not be independently turned off.
Hardware platforms affected : HP EliteBook 8440p Notebook PC, HP EliteBook 8540p Notebook PC, HP EliteBook 8740w Mobile Workstation
Support Communication Cross Reference ID : IA02641880
