HP Folio 13 Notebook PC - Removing and Replacing the Power Connector Cable
Removing the power connector cable
Before removing the power connector cable, follow these steps:
  1. Shut down the computer. If unsure whether the computer is Off or in Hibernation, turn the computer On, and then shut it down through the operating system.
  2. Disconnect all external devices connected to the computer.
  3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and then unplugging the AC adapter from the computer.
  4. Disconnect the display panel cable from the system board. Click here for instructions on how to remove the display panel.
  5. Turn the computer, with the right side towards.
  6. Disconnect the power connector cable (1) from the system board.
  7. Remove the double-sided tape (2) from the power connector.
  8. Remove the power connector cable (3).
    Figure : Power connector
Replacing the power connector cable
  1. Place the power connector cable in its position.
  2. Reconnect the power connector cable to the system board.
  3. Attach the double-sided tape to the power connector.
  4. Turn the computer, with the right side away.
  5. Replace the display panel cable from the system board. Click here for instructions on how to replace the display panel.
  6. Reconnect the power to the computer by first plugging the power cord into the AC outlet and then plugging the AC adapter into the computer.
  7. Reconnect all external devices to the computer.
  8. Turn On the computer.
Country: Flag Thailand
