HP Keyboards and Mice - HP Link-5 Datasheet
This document pertains to the HP Link-5 USB micro receiver.
This is an edited copy from the printed format of the HP Link-5 data sheet. To obtain a better representation of the printed form, refer to the manuals section of this product’s support site.
Figure : HP Link-5 USB micro receiver
What is Link-5?
HP Link-5 technology makes it easy to link up to five compatible HP wireless mice or keyboards to the same USB micro receiver.
Benefits of Link-5
  • All your devices will be ready to use where ever and whenever you need them without having to shuffle around multiple receivers.
  • Use only one USB port for multiple devices.
Using Link-5
If you already have a Link-5 receiver plugged into a USB port on your PC, there is no need to plug in an additional receiver. To pair your keyboard or mouse, move it to within 1 foot (30cm) of your existing Link-5 receiver, press the Connect button on the bottom of the device, and then press a key or click a mouse button.
Troubleshooting Link-5
For Link-5 questions, please refer to http://www.hp.com/support.
Link-5 Mouse and Keyboard LED Information
Mouse Scroll Wheel LED
Keyboard Sleep LED
In pairing mode
2 blinks per second.
The mouse will stay in pairing mode for 10 seconds.
LED stays on.
The keyboard will stay in pairing mode for 10 seconds.
Device successfully paired
5 blinks per second, stops after 10 blinks.
