HP Ink Cartridges - 'Use SETUP Cartridges' Error
This document is for HP inkjet printers.
Use SETUP Cartridges displays on the printer control panel or computer, and the printer does not print.
If you see an ink cartridge error message other than Use SETUP Cartridges, go to HP Customer Support, search for your printer model, and then find the troubleshooting document that matches the error you see.
The steps to troubleshoot vary by the type of ink cartridges your printer uses. Identify your ink cartridge type, and then follow the steps to resolve the issue.
HP ink cartridges
HP ink cartridges
HP ink cartridges
