HP LaserJet and Color LaserJet Enterprise MFP's - Improve print quality with Windows
Select the page size with Windows
  1. On the File menu in the software program, click Print.
  2. Select the product, and then click the Properties or Preferences button.
  3. Click the Paper/Quality tab.
  4. Select a size from the Paper size drop-down list.
Select a custom page size with Windows
  4. Click the Custom button.
  5. Type a name for the custom size, specify the dimensions, and click the OK button.
Select the paper type with Windows
  4. From the Paper type drop-down list, click the More... option.
  5. Expand the list of Type is: options.
  6. Expand the category of paper types that best describes your paper, and then click the paper type that you are using.
Select the paper tray with Windows
  4. Select a tray from the Paper source drop-down list.
Select the print resolution
  4. In the Print Quality area, select the resolution from the first drop-down list.
