Adding or Replacing an Expansion Card (Video Card, Sound Card, etc) in HP Pavilion p6000, p6-1000 and p6-2000 Series Desktop PCs
This document pertains only to HP Pavilion computers with the following computer case:
Before you begin
  • You need a flathead screwdriver. Note that you need a screwdriver with a long shaft when you are replacing a long graphics card.
  • Turn off the computer, and then disconnect all cables. Disconnect the Ethernet or modem cable before disconnecting the power cord.
  warning:
Video overview
Removing the retaining bracket and/or an expansion card
Use the steps in this section to remove the retaining bracket from the computer and to remove an existing card. You must remove the bracket before you can remove or install an expansion card.
  warning:
Step 1
Remove the right side panel.
For more information about removing the side panel, refer to the HP support document Opening the PC Case.
Removing the side panel
Step 2
Locate the expansion card slot lock on the back of the computer.
Expansion card slot lock
Step 3
Remove the screw connecting the slot lock to the computer.
Removing the screw connecting the slot lock to the computer
Step 4
Pull the expansion lock off the computer.
Pulling the expansion lock off the computer
Step 5
Detach any connectors from the expansion card.
Detaching connectors from the expansion card
Step 6
Pull on the edges of the expansion card to remove it from the expansion slot.
Pulling the expansion card out of the expansion slot
Installing an expansion card
Use the steps in this section to install a new expansion card.
Step 1
Carefully put the expansion card in the expansion card slot until it is secure.
Securing the expansion card
Step 2
Reattach any connectors to the expansion card.
Areas for connectors to be reattached
Step 3
The expansion slot lock has two hooks that fit into two slots on the back of the computer.
Expansion slot lock
Slot lock holes in computer
Step 4
Align the hooks of the slot lock into the slots on the back of the computer, and slide the lock into place.
Slot aligned with the slot lock
Step 5
Replace the screw for the expansion slot lock.
Expansion slot lock screw
Step 6
Replace the right side panel.
For more information, refer to the HP support document Opening the PC Case.
Sliding the side panel toward the front of the computer
