HP ZR2240w 21.5-inch LED Backlit IPS Monitor Product Specifications
Product description
The HP ZR2240w 54.6-cm (21.5-inch) LED Backlit IPS Monitor has a new LED backlight, HDMI input and 1920 x 1080 full HD1 resolution in an ultra-modern design that is sleeker than ever to perfectly complement HP Z Workstations.
Product features
Feature
Type
IPS (In-Plane Switching) LED Backlit LCD
Viewable Image Area (diagonal)
54.52 cm (21.5 in) widescreen; diagonally measured
Optimal resolution
1920 x 1080 (Full HD) @ 60 Hz
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
User programmable modes
Yes (20)
Anti-glare
Yes
Plug and play
Yes
Tilt range
-5° to +35°
Swivel range
Yes (+/- 45°)
Height adjustable
Yes (9 cm)
Response time (typical)1
8 ms (gray to gray)
Pivot rotation
Yes
1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Panel specifications
Specification
Type
IPS (in-plane switching) LED Backlit LCD
Screen opening (W x H)
47.5 x 26.7 cm (18.7 x 10.5 in)
Optimal resolution
Aspect ratio
16:9 Widescreen
Maximum brightness (typical)1
250 nits cd/m2
Minimum brightness (typical)1
50 nits cd/m2
Contrast ratio (typical)1
1000:1
Dynamic contrast ratio (typical)1
2,000,000:1
8 ms (gray to gray)
Pixel pitch
0.2475 mm
Backlight lamp life (to half brightness)
30,000 hours minimum
Color gamut (typical)
72%
Color support2
Up to 16.7 million colors
2. With the use of FRC technology.
On Screen Display (OSD) controls specifications
Specification
Buttons or Switches
  • Menu
  • OSD -
  • OSD +
  • OK
  • Power On/Off
Languages
  • English
  • French
  • Spanish
  • German
  • Italian
  • Dutch
  • Brazilian-Portuguese
  • Japanese
  • S-Chinese
  • T-Chinese
User controls
  • Brightness
  • Contrast
  • Positioning
  • Color temperature (5000K, 6500k, 9300k, custom)
  • Individual color control
  • Serial number
  • Display
  • Clock
  • Clock phase
  • Monitor management
  • Factory reset
Signal interface/performance specifications
Specification
Horizontal frequency
24 to 94 kHz
Vertical frequency
50 to 76 Hz
Native resolution
1920 x 1080 @ 60 Hz; Full HD
Preset VESA graphic modes (non-interlaced)
  • 1920 x 1080 @ 60 Hz
  • 1680 x 1050 @60 Hz
  • 1600 x 900 @ 60 Hz
  • 1440 x 900 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 800 x 600 @ 60 Hz
  • 640 x 480 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
200 MHz for VGA; 165 MHz for DVI, HDMI and DP inputs
Yes (20)
Anti-glare
Yes
Default color temperature
6500 K
Video/other inputs specifications
Specification
Plug and play
Yes
USB 2.0 hub
One upstream, four downstream ports (cable included)
Input connectors
(1) DVI-D connector; (1) VGA connector; (1) DisplayPort connector; (1) HDMI connector; (HDCP support on DisplayPort, HDMI and DVI)
Input impedance
75 Ohms (VGA)
Sync input
TTL separate synch
Video cables
DisplayPort, DVI-D and VGA
Video cable lengths (VGA, DVI-D, DisplayPort)
1.8 m (5.9 ft)
USB cable
USB cable length
1.8 m (5.9 ft)
Electrical specifications
Specification
Input power
90 – 265 V ac, 50 to 60 Hz
Energy star power1
31.6 W
Default power2
35 W
Maximum power3
52 W
Power saving
< 0.3 W sleep (standby)
Power cable length
1.9 m (6.2 ft)
1. Energy Star power is measured with factory defaults, brightness at Energy Star level of 200 cd/m2 and with no USB loads.
2. Default Power is measured with factory defaults, including factory default brightness and USB ports loaded at 25% of maximum.
3. Maximum Power is measured with monitor at maximum brightness and with USB ports loaded at 100% of maximum.
Physical specifications
Specification
Dimensions (W x D x H)
Unpacked with stand
  • 50.8 x 23.4 x 36.7 – 45.7 cm (20.0 x 9.2 x 14.4 – 18.0 in)
Unpacked without stand (head only)
  • 50.8 x 5.9 x 30.3 cm (20.0 x 2.3 x 11.9 in)
Packaged
  • 57 x 39.4 x 29.5 cm (22.4 x 15.5 x 11.6 in)
Base area (footprint)
  • 29 x 23.4 cm (11.4 x 9.2 in)
Head only
  • 3.48 kg (7.7 lb)
Unpacked
  • 5.74 kg (12.7 lb)
Packaged
  • 7.9 kg (17.4 lb)
Environmental specifications
Specification
Temperature
Operating
5° to 35°C (41° to 95°F)
Non-operating
-20° to 60°C (-4° to 140°F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%, 38.7°C max wet-bulb
Altitude
Operating
0 to 5,000 m (16,404 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
White LED backlight
Yes
Arsenic free glass1
Yes
BFR/PVC free2
Yes, except cables
Mercury free
Yes
1. Arsenic and its compounds were not detected using US EPA Test Methods 3052 & 3052/6010b by ICP or ICP-AES.
2. Meets the evolving definition of 'BFR/PVC-free' as set forth in the "iNEMI Position Statement on the 'Definition of Low-Halogen' Electronics (BFR/CFR/PVC-Free)". Plastic parts contain < 1000 ppm (0.1%) of bromine [if the Br source is from BFRs] and < 1000 ppm (0.1%) of chlorine [if the Cl source is from CFRs or PVC or PVC copolymers]. All printed circuit board (PCB) and substrate laminates contain bromine/chlorine total < 1500 ppm (0.15%) with a maximum chlorine of 900 ppm (0.09%) and maximum bromine being 900 ppm (0.09%). External cables (power, video and USB) are not BFR/PVC-free. Service parts after purchase may not be BFR/PVC-free.
Safety certifications
Certifications
Certification and compliance
  • ENERGY STAR 5.1
  • EPEAT Gold1
  • TCO Displays 5.2
  • CSA-NRTL
  • CSA
  • FCC
  • CE
  • TUV
  • GOST
  • NOM
  • IRAM mark
  • PSB
  • VCCI
  • KC/KCC
  • Korea E-Standby
  • ISC
  • BSMI
  • C-Tick
  • CCC
  • CECP
  • CEL
1. EPEAT Gold where HP registers commercial display products. Click here to check for registration status in your country.
Warranty information
Terms of warranty apply to the individual model purchased. To see if your HP product is still in warranty, go to the HP Product Warranty Check page.
