HP ZR2240w 21.5-inch LED Backlit IPS Monitor - Overview
Product description
The HP ZR2240w 54.6-cm (21.5-inch) LED Backlit IPS Monitor has a new LED backlight, HDMI input and 1920 x 1080 full HD1 resolution in an ultra-modern design that is sleeker than ever to perfectly complement HP Z Workstations.
Product features
Feature
Type
IPS (In-Plane Switching) LED Backlit LCD
Viewable Image Area (diagonal)
54.52 cm (21.5 in) widescreen; diagonally measured
Optimal resolution
1920 x 1080 (Full HD) @ 60 Hz
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
User programmable modes
Yes (20)
Anti-glare
Yes
Plug and play
Yes
Tilt range
-5° to +35°
Swivel range
Yes (+/- 45°)
Height adjustable
Yes (9 cm)
Response time (typical)1
8 ms (gray to gray)
Pivot rotation
Yes
1. All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
Links to QuickSpecs
Direct links to the QuickSpecs will be added as soon as they become available.
